04 A/C problems
138K views 67 replies 47 participants last post by  pello2023
I believe there is only 1 relay for the clutch. It is in the relay block under the hood by the battery. It is marked 'MC' MG CLT. Try and swap it out with a known good relay. The horn relay will work. It is not used much so it should be a good test relay. The colour of the relays maybe different but will work.
Let us know how it goes.
Edit by robo5 : corrected relay name.
