That car care nut loves notoriety!
You inspired me to take a closer look. Here’s what I saw. Apologies for random order of pictures.
This is what’s wet and grimy, the far driver side end of the transmission above and aft of the mount -
Brake master and ABS pump are clean and dry. I don’t have a picture of the bottom of the ABS pump. I’m not losing brake fluid -
Looking from the wheel well, the inner boot is dry and cleaner than the transmission end -
Outer joint fully flexed. Looks clean and dry to me -
Closer view of inner joint -
Rack boot is fairly clean and far from transmission end -
Could it be a liquid filled mount sprayed out?
FWIW we had a ‘97 Grand Caravan from 97K miles to 262K miles which developed a leak from a cover plate in that area. For all it’s… ahem… earned notoriety, that 41TE only needed that cover plate resealed and a solenoid pack which Chrysler was thoughtful enough to mount outside the transmission.
Sixto
‘04 LE FWD 194K miles
