What did you replace when you heard the clicking?
If you replaced the servo for the mode control, then I am guessing that one of the pins for the door wasn't installed correctly. I just finished replacing this part on my van yesterday. Each path for the blend door pins (3 total) have a little "window" on the back side so you can install it correctly. The window is there so you can see the pin in each slot.
