Hello all,
2008 LE, 145,000 miles. After driving on the highway normally for 30 minutes last Saturday, I got check engine, VSC and TRAC OFF lights on when I started it again. I used OBD2 scanner at Autozone and got P0302 code. At first I thought it was because of ignition coils. However, the lights were still on after I replacing the front three coils (cylinder 2,4,6).
Took it to my mechanic for futher check. He found radiator crack, which caused coolant leaking, engine overheating, blown head gasket and cylinder #2 misfire. Some coolant was found in the cylinder. I asked why the temperature gauge didn't show anything wrong while driving, he told me the gauge would lie sometimes (he explained the reason but I didn't understand).
He quoted $2637 in total for fixing everything, including rebuilding cylinder head, replacing head gasket, water pump, radiator, thermostat, spark plug, ignition coils (the new coils I bought), and changing oil and coolant.
Any thoughts on the quote? How do you think spending such money on this old van? I bought it last year for $8900 and drove it for 10,000 miles. But I guess I would also loss a lot if I sell it now with these problems.
Want to share this experience to you. Thank you!
