Under approximately what load?For reference I have tested the inverter to confirm it is pure sine wave output
No idea 🤷🏽♂️Looks pretty smooth, what are those three little hiccups?
This is exactly why I want to car camp in a Sienna hybrid! Loved it on our Prius.
....And easily removable seatsThis is exactly why I want to car camp in a Sienna hybrid! Loved it on our Prius.
If only Toyota made a Sprinter high roof sized van...
Seats are a none issue for me. Easy enough to remove with some tools.....And easily removable seats
Curious why you didn’t just get the oem 1500watt? Seems like a lot of $$$ and trouble when the vehicle has many of those things. You’re looking at $4,000?I am wanting to do something similar. Will start with removing the 3rd row seats. Will place 2 100Ah Lithium batteries. A 2000w inverter/charger, a 30a DC to DC Charger to charge the batteries from the 12 battery in the back, a 12v USB ports, associated battery terminals, Busbar, cables etc. I believe that all this will fit in the 3rd seat space. This should provide power for a fan, and a small heater, and other associated things. Hopefully good for overnight trips, etc.
John
How are you covering up the sharp seat rails? How often do you plan on putting the seats back in? Were you able to turn off the constant air bag warnings? Thank you for answering my silly questions.Seats are a none issue for me. Easy enough to remove with some tools.
All good points, I felt that having the additional battery backup would be an advantage,Curious why you didn’t just get the oem 1500watt? Seems like a lot of $$$ and trouble when the vehicle has many of those things. You’re looking at $4,000?
You should be able run the hybrid Sienna’s HVAC overnight.
I can understand if you want to run a fridge when the vehicle is off and parked. A Dometic PLB40 solves that, gives you USB and 12v power.
Also, that I didn't remember at the time, the dealer that I used stated that to get the inverter that I had to order the plus package, and the entertainment package, that added up to $3500, curious to see if anyone can get the inverter with the plus package and not the entertainment package.All good points, I felt that having the additional battery backup would be an advantage,
It's almost criminal that a $300 extremely functional and desired option, costs over 10k. Just offer the damn option for $300 on every trim, including LE. Even mark it up more, to make it more profitable. Texas just proved they can sell that option on every hybrid for a good profit. Wake up toyota. A little good will.... pleaseAlso, that I didn't remember at the time, the dealer that I used stated that to get the inverter that I had to order the plus package, and the entertainment package, that added up to $3500, curious to see if anyone can get the inverter with the plus package and not the entertainment package.
In the maybe 1x in 5 years (hence why its a non issue for ME) I would do it I'm sure I can cover the rails with something, looks like 2 1x4s with a spacers would easily cover them and use the existing hole to secure it.How are you covering up the sharp seat rails? How often do you plan on putting the seats back in? Were you able to turn off the constant air bag warnings? Thank you for answering my silly questions.
You just need the plus package to get the inverter (on the XSE at least) Its shown on the website.Also, that I didn't remember at the time, the dealer that I used stated that to get the inverter that I had to order the plus package, and the entertainment package, that added up to $3500, curious to see if anyone can get the inverter with the plus package and not the entertainment package.
There is a reason items are in packages and not a la carte bespoke builds. It would increase overall MSRP for everything by slowing the production line to a crawl.It's almost criminal that a $300 extremely functional and desired option, costs over 10k. Just offer the damn option for $300 on every trim, including LE. Even mark it up more, to make it more profitable. Texas just proved they can sell that option on every hybrid for a good profit. Wake up toyota. A little good will.... please
re - aftermarket - 1500W sine wave inverters can be had for less than $300 for the device only - but the owner's manual implies a fairly high level of integration with the hybrid system (temperature and state of charge of the traction battery) - could the smallish 12V battery in the Sienna and the 12V charging system run the aftermarket inverter reliably?There is a reason items are in packages and not a la carte bespoke builds. It would increase overall MSRP for everything by slowing the production line to a crawl.
You gotta pay to play. If you needed a 1500 watt inverter you can easily put one in aftermarket.
Which brings me to the question; what exactly does the 12V battery in the rear power? Does the hybrid battery only power the electric motors?re - aftermarket - 1500W sine wave inverters can be had for less than $300 for the device only - but the owner's manual implies a fairly high level of integration with the hybrid system (temperature and state of charge of the traction battery) - could the smallish 12V battery in the Sienna and the 12V charging system run the aftermarket inverter reliably?
12V only really boots the computers and provides initial power up to 12v accessories, 12V also powers the HVAC blower motors. Engine starts, AC compressor, etc are powered from the traction battery.Which brings me to the question; what exactly does the 12V battery in the rear power? Does the hybrid battery only power the electric motors?
Thank you. I mistakenly thought you were the guy that was going to leave out the seats long term.In the maybe 1x in 5 years (hence why its a non issue for ME) I would do it I'm sure I can cover the rails with something, looks like 2 1x4s with a spacers would easily cover them and use the existing hole to secure it.
I would just ignore the seatbelt light for the day or two.
If I had more than 2 sheets of 4x8 or larger items I'd just rent Home Depot's truck for $20. Again thats for my usage.
I can find out! I have a 1k and 2k sine wave inverter sitting around. The size of the fuse leads me to believe serious current is going to that 12vre - aftermarket - 1500W sine wave inverters can be had for less than $300 for the device only - but the owner's manual implies a fairly high level of integration with the hybrid system (temperature and state of charge of the traction battery) - could the smallish 12V battery in the Sienna and the 12V charging system run the aftermarket inverter reliably?
Is the 1500w inverter hooked up to the traction battery or the 12v battery. Ah, I see the question was asked already though not definitively answered.re - aftermarket - 1500W sine wave inverters can be had for less than $300 for the device only - but the owner's manual implies a fairly high level of integration with the hybrid system (temperature and state of charge of the traction battery) - could the smallish 12V battery in the Sienna and the 12V charging system run the aftermarket inverter reliably?
