I have a 2000 Sienna XLE with 80,000 miles. Last year I was verbally advised by my local dealership that Sienna motor mounts should be replaced as routine maintenance item with these older Siennas. However, this dealership has something of a reputation for over selling repairs. Last year they verbally advised me to have it done next time the van was in. At that time they initially they quoted 600.00 for all 4 mounts. Now they estimate 1600.00. While I don't mind helping a service advisor make his boat payments (if the work is really needed), I am somewhat skeptical.
I am wondering how many of you needed motor mount replacement. If so, did you use Toyota parts, and about what was the cost.etc
Secondly, What is the best way to check the motor mounts?
My upper "dogbone" mount seems visually to be fine, the rubber is intact etc. The motor does not shake or jolt when putting the van in drive and then reverse, with foot on the brake. The van drives smoothly with little or no vibration, etc..
The lower rear mount seems to be the hardest to change as the axle has to come out to get the mount off. It is also the hardest to see..
Any thoughts from other Gen 1 owners would be most appreciated.
