1 - 8 of 8 Posts
Hello i have a 2002 toyota sienna with 150,000 miles. I owned it since new and recently i was getting tired of it, but rather than selling it i decided to do an small overhual with some upgrades, i replaced the timing belt and components, alternator and starter, battery and i also replaced the idle air controll valve as these siennas do have problems with those, i also did spark plugs, pcv and valve cover gasket replacements, the transmission had an aftermarket cooler installed, for the suspension i did the axles, axle seals lower control arms, tie rods, wheel bearings, struts and shocks, brake caliper and brake rotors and pads, i also replaced the stabilizer links. for the rear of the car i did the rear shoes and cylinders along with the master cylinder. I moved on to the interior of the car where i installed a double din touch radio unit and a backup cam, where i also replaced the broken tailgate latch. I also wired in a 110v outlet and game port along with a 10in flip down monitor for movies and games. from here i upgraded the instrument cluster to one with a tachometer as the ce siennas only have a speedo. I also removed the green caps on the dash bulbs to make them light up yellow, after this i disassembled the car where i installed fog lamps and led lights, i also dissembled the panels so that i could paint repaint the body to woodland green pearl and the cladding to a gloss gray. i found some nice alloy wheels from a Camry that I installed because i hate the look of hubcaps.... lastly i was looking for tips as to what to do with the interior as in the ce the second row has bench seats and i was wondering if i can install the upgraded captains seats. i was also wondering if it would be possible to upgrade the drivers and passenger seats to one with the side airbags as the ce model didnt have that feature.>:) ill later post some pictures>:)>:)
Post some pictures please,
I recently put in a turbo on my car and it flys, reached speeds of 120mph, with out any issues, but you need to have racing type of tires ( Z rated ) or else if you did that with a regular tire it would burst into a million pieces,
Z speed rating
A Z speed rating indicates the tire has been approved for speeds of 149+ mph (240+ km/h) under optimal conditions. This rating is associated with maximum tire performance and is a match for performance coupes and sedans, sports cars, and supercars.
While speed rating is typically adjacent to the load index, and outside of (after) the tire size expression, the Z speed rating can be found within the structure of the tire size:
235/40ZR18
Amazing what you can do with the equivalant of a couple car payments. How's the radio? I just ordered one just like it for my 30 year old car. Only one that would fit.
When you replaced the instrument cluster, did it change your odometer? I'm thinking of doing the same thing to my CE, but I don't want my odometer to change.
Z speed rating
235/40ZR18 View attachment 44671 View attachment 44671
X I have a 2001 with over 433,000 miles with the same drive train. I would recommend a heads up display. It hooks up to the OBD II under the dash. I love it. As well as addedd a rearview camera on my mirror.I used the direct wiring, which is way harder but the the picture is far superior than the nonwired version which I have in my 2005 Highlander.
[/QUOTE]
I've been looking for upgrade ideas. I like this one! Where did you find it, can you specify a model on amazon or something?
Can you detail the turbo build and the cost?
Genuinely interested
Considered the supercharger that TRD made but, at $2500 for like 20hp it really didn't seem worth it at all
1 - 8 of 8 Posts
