2004 Sienna AC is blowing out hot air.
4764 Views 3 Replies 4 Participants Last post by  cprimero
Hi All,
I have a 2004 Toyota Sienna, has 130K miles on it. Recently, all of sudden my AC is blowing out hot air. Still when I on the AC, the Green light is on and hot air is blowing out. I gave the car to a Toyota dealer and they have re-pressure the AC (for $75.00). After that the AC problem still exists, again I have asked the Toyota dealer to check it. They have inspected and quoted for $1300.00 for replacing something.
I do not want to spend that huge money hence I decided not to replace that; now, it's getting hot and fried out without the AC.
Can someone assist/help, is there an easy/less expensive fix places around Evansville, IN area? Since I am not a mechanic, I do not want to replace/change anything myself (if it is too complicated).
Please help & advise.
Thank you!
Get ready to start spending $$$. Did they do a leak test? I have a 98 Sienna and my rear line ruptured. Replaced it once, and it lasted for a year.
You need to find out what the problem is first.
Check the relay near the battery. It's 15.00... Google it..
SO I take it that $1300 quote is for a compressor.
Relay may fix it if clutch has trouble engaging. to test you can swap the mg-clt relay for the horn relay in the fuse box.
