1 - 10 of 10 Posts
Hello:
I have no heat in the van. I have looked at fuses and they seem good.
I need to defrost the windshield - the AC works great but no heat.
Any ideas as to what might be going on?
Cheers.
Moved to gen2
2009 le awd
Two possable reasons. The core is plugged, both heater hoses should be warm.
Coolant should flow thru it at all times.
If it were plugged one would be cold or cooler at least.
The second would be the blend door is not functional .
This opens and closes to allow airflow thru the heater core.
Discussion Starter · #9 ·
OK
I will look into these two probable issues.
Cheers.
1 - 10 of 10 Posts
