Can you put it into 'Normal' mode while going down the road? You turn the cruise on and push the cruise lever in toward the dash for a few seconds to change the mode. Are you saying that even this method will not work? If so, it could be your sensor that has failed. Mine will 'fail' if I am driving into the sun because the sensor is overwhelmed by the intense rays.
