One connection to the positive terminal of my Sienna’s battery needed its lug replaced requiring me to temporarily disconnect the battery. Since then, I can't get my 2004 Sienna LE to pass the “readiness monitors” so that I can get my state inspection, though it drives fine. (These are little tests that the car’s computer does in the background to verify that all systems are working properly and that the car is ready for emissions testing.) In the past, it never took much more than 100 miles of random driving to get all monitors to clear. This time, though, the EVAP and CAT monitors won't clear. A mechanic has verified this on his code reader as well. Also, we have both found that no codes or pending codes are set.
ILSienna256K reported on this site a very similar problem on a 2004 Sienna with the same 2 monitors, EVAP and CAT, stuck on “not ready”. Smog fail "Cat not ready"
But ILSienna256K reported that he was finally able to clear these monitors by following the drive patterns listed as “4” and “6” in this Toyota Technical Service Bulletin (TSB) so that his Sienna was ready for state emissions testing. I have very carefully followed drive pattern no. 6 to no avail. A note for drive pattern 6 in the TSB reads: “When the Readiness Monitor or DTC is set, this test is complete.” (“DTC” means Diagnostic Trouble Code.) This note is located immediately below the specified test period of 15 - 50 min. of idling. I interpret this information as meaning that A.) within 50 min, either the Toyota will clear the EVAP monitor OR B.) a DTC will be set. The other thing that this implies to me is if neither of these things happens, there is a problem with the Powertrain Control Module (PCM= same as an Engine Control Module, ECM, except that in Sienna it also controls the transmission). My tentative conclusion is that there is a problem with the PCM because if there were a bad sensor or bad connection, a code should be thrown. Does anyone out there have specific knowledge about this? Am I understanding the results of this test correctly? Does my PCM need to be replaced or re-flashed?
