2005 Toyota Sienna XLE AWD - engine light on, misfire on #6
76 views 3 replies 3 participants last post by  BillG
my engine light came on after I had my car serviced at 262 k miles. I had my front spark plugs changed . Then I left and the engine light came on again with a coil#6 error. I replaced the coil with a Toyota coil. After 200 miles of driving the engine light came on again. Same error coil # 6 misfire. Obama st a loss of what to do ?
#2 ·
At 262k miles the connector at the coil , if original , is probably dry and crumbling and may need a new termination. Check that first. What brand of spark plugs did you install and where did you buy them? Install another spark plug and see what happens.
