1 - 14 of 14 Posts
2006 LE
I recently did an oil change and if you are like me , you would wipe clean the bung area of the oil pan , start the engine and check for leaks at the filter and the oil bung. I did not get to the point of starting the engine. Why? It seemed to me that the oil bung was not seated as I normally see. Sure enough the old washer was still there. Geez. So I drained the oil and buttoned up things again. BUT what was interesting was how the new oil looked once it was drained. It looked dirty not like the clear light honey color of new oil. So I researched engine flush , the pro and cons and the various ways of doing so and the one that I like the most is actually doing an oil change as usual then drive for a bit then renew the oil and filter and take it from there. Seems like a waste and I question whether or not an engine flush is even necessary if you change the oil regularly. Thoughts?
2009 le awd
Some might put this into the same category as a trans flush, best to take what gravity will give you and leave the rest alone. I do run some sea foam for 200 miles before oil change and dump the other half into the fuel tank but who knows if there is any benefit. The only reason I did this was because of a vvt code that would pop up on a rare occasion. Dirty oil or too long of a duration between changes seemed to one possible cause. I was going for 10,000 between and have since settled on 8,000.
I had this other car with a screw on filter and I was 100 % Sure I had the face cleaned off good but the rubber seal was still on it so it had two of these now. It must have pumped 3 quarts of oil onto the floor in like 30 seconds.
What oil did you drain then fill? I ask because we had a Caravan with sludge visible through the oil filler hole. I imagine the PO ran dino oil. A few changes with Mobil1 back when it was more synthetic than it is now cleared most of the sludge.
Did it look dirty on the dipstick as well on only while pouring and in the pan? Do you have an oil cooler that doesn’t drain through the pan?
Sixto
‘04 LE FWD 207K miles
2006 LE
Discussion Starter · #6 ·
No , The oil looked clean on the dipstick.
No to an engine flush per ericreyn's link. I would run the oil for 500 miles then change it. Also shorten the oil change interval. Mine is 5k or 6 months. Oil is cheap, engines aren't!
This is what I would do as you suggest. And Yes I'm a 5k 6 month believer.
Year before last I pulled out the vvti screens and they were clean! This after over 175k miles. I am now at 209k miles. That was encouraging!!
Reactions: supra129
quite often an "engine flush" additive will cause other problems like leaks from the main sean, and leaks from the pan and other areas. USUALLY the engine flush products are ONLY used if you HEAR audible noises IE hydraulic lifters or other noises from the top end of the motor.
That being said, the 2 BEST options you have for motor "cleaning" would be marvel mystery oil, OR rislone engine treatment. You can research them but both are highly recommend and prosper amazing results.
Again, these products are usually used if your motor is making lighter tapping noises. If it's a deeper knocking or tappin. then your motor has serious issues,.
I wouldn't be too concerned. The oil pan holds the worst of the worst oil in the bottom half inch or so. If you really wanted to "flush" it out, you could always put the plug in, pour in half a quart, then pull the plug again and drain that out. That said, if you aren't getting lifter noise at cold start (hard to do in FL, I imagine), I probably wouldn't put any money into an engine flush. Back in the day, you would get a beater that leaked a little oil out of the rear main. You'd add a quart per week. Every 3 months, you spin off the old filter and spin on a new one. No oil change was required because it was on a continuous change interval.
Probably an easier, lest costly way:
When you change your own oll, after removing oil drain plug and filter, wait a couple hours for it to fully drain. Then, before you put back the drain plug, pour into your oil intake maybe a half or so quart of new oil. (Lots of cars take 4.5 quarts or 5.5 quarts). Wait for that to drip thorough then put you plug and oil filter on.
If you have someone helping you, and you are down below, you can see the new oil "push out" the dirty old oil which was not removed. Its cheaper and faster. You can skip the waiting, too, but its better to wait until your oil all drains down. The idea is you have more nearly 100 percent new oil and only a very small portion of used oil inside your engine.
Sounds like it’s a matter of how much you think about it :) Yes, a key point of changing oil is getting dirt and nastiness out of the engine so the more you remove the better. I wonder how much internal surface area that half quart of oil flows over on its way to the drain. I imagine not much. Maybe the compromi$e to avoid chemicals is a 200 mile flu$h with fre$h oil :eek: Or maintain a more reasonable drain interval than some oil manufacturer’s [crazy to me] 15k mile recommendation. I lose sleep if oil has been in the engine more than 5k miles. Thankfully I can afford to appease myself. There are people who lose sleep after 3K miles.
This is much better than the indirect injection Diesel days when fresh oil looked like what you just drained after a drive around the block.
Sixto
Doing this will not help with engine "sludge". The sludge sticks to the hydraulic lifters and oil passages caused by previous owners waiting to long for oil changes.
IMO there are 2 effective and safe ways to clean an engine if you notice/suspect the sludge.
The first is marvel mystery oil. Super effective, and proven to work. The other is an old school method, 1 quart of ATF with the remainder oil.
Both are proven ways to clear sludge and fix upper end noises or hydraulic lifters.
I am always concerned with engine or transmission flush, especially with additives.
with a transmission flush that means they hook up a pressure machine, and pump the fluid around. Of course, you never want to do that.
Most of the "engine flushes" are just a quart or two. Then you run the engine for 5 minutes. Drain everything, and then do a brand new oil change. Again, these methods sometimes cause leaks at the rear main seal. Not a good idea. You are better off using marvel mystery oil, or 1 quart ATF.
MMO has been around for AGES, and it works wonders at cleaning the engine.
The quick easy flush I described, above, wont "clear sludge", per se, but a constant wash in the cleanest oil possible, will. This is what this intends to accomplish by this simple method to make sure as much as possible of the "dirty" oil is flushed at oil change. When you pour in clean oil, it becomes slightly diluted with dirty oil, left in your engine at oil change, at your new oil change. Using the method I described, means there will be less dirty oil to dilute the clean oil. Its kinda like trying to wipe something clean with a very dirty soiled oily wrag..it does not work that well, but instead spreads dirt all over the surfaces you intend to clean. Instead, wipe it off with as clean a wrag as possible.
In the same way, the method, above, cleans at least SOME of the dirty oil left in your engine at oil change. Disassembling the engine, of course, would allow a full sludge removal.
A family member, with extensive motor cycle racing experience, recommends Amsoil. I did check the Amsoil website, where the sludge removal is documented, by actual engines broken down after use, along with otther testing procedures.
I found no such oil testing results at Marvel Mystery Oil. While test results can be manipulated, these third party oil tests did demonstrate that my cousin's opinion on the value of Amsoil was spot on.
Instead of relying upon anecdotal evidence "My uncle said this brand of oil was best, so it has to be the best", I prefer documented comparison testing. While car companies dont recommend oil additives, such as Marvel Mystery oil, Amsoil products are good enough so that you warranty is still in force after using Amsoil at oil change instead of other brands. Indeed, the lubrication engineers which work for the car companies, review the tests. As far as I know, none of the major car companies recommend oil additives, but do provide lubricant quality specificiations, supported by testing.
For my vehicles, I will do what the engineers recommend, as opposed to ancedotal evidence. For that reason, I dont use oil additives.
1 - 14 of 14 Posts
