Given the advances in emitter technology, this will eventually become practical. Right now you are trading your safety on a dark road for good looks in the daytime.
We know that in HIGH BEAM mode, the bulb socket receives the full 13.5 volts, while in DRL mode it gets around 6-7 volts. A 9005 incandescent bulb will be full 1700 lumen at 13.5v, about 350 lumens at 6 volts (half the voltage = 1/4 the power). The "decoder" is likely a buck-boost to level out the voltage at something between these two values, and the LED's are wired to correspond to it. The Cree units says 5 watts for the front emitter, and with their mid to higher end products I'd figure that we are looking at around 600-800 lumens or so? The 5050 emitters stacked around the side are garbage - around 20 lumens each, so another 250 lumens but with poor spread given where they are located. Net is that it's a pretty DRL, but would likely suck as a headlamp.
