Just wondering if anyone else has experienced this problem. It's leaking coolant from right under the engine, not around the radiator or that area. Vehicle has 115,000 miles. Afraid it might need water pump replacement, hoping something cheaper like thermostat.
there as i small plate which they call frezzee plug on front of motor which will leak easy fix execpt sealant is expensive had it done at toyota garage about$150
Just had mine leak around the thermostat housing. Ran down and dripped from almost dead center near the front differential. Changed the thermostat and gasket.
