14yrs dealing with the poor cargo area lighting at night finally put to rest. Figured I'd share as I found it much easier to do and even within my normal mod standards.
1. Had to do minimal modification to any body panel, plastic, etc.
2. Make use of existing light for a power connection and possibly a switch
3. Bonus, do this without buying anything new (scavenge parts from my workbench and other projects)
Pretty straight forward. Basically the top middle trim paneling pops down easily, you really only need to loosen the left 3 or 4 body panel connectors. Just pull down gently and they will pop right out. I stopped around the middle rear seatbelt area.
Gently pull the rubber weather seal off the left side of the hatch, near where the lift strut is. It is just pressure fit on there and will pop back on easily later.
Pull out the existing light assembly to give a little more room for access though I ultimately used a glow rod to help fish the wire down and behind the light assembly area.
Wiring was really straight forward, so much so I didn't bother taking a picture. Essentially use your meter at the 2 small tab connections where the factory light is connected. I believe on mine the outer most pin was positive and the middle was negative, but ONLY when the switch was toggled to turn off the stock light. This was a bonus for me as I wouldn't need the extra light all the time so why not make it a toggle.
I ended up using 1 of the leftover undercabinet LED lights I put into our kitchen. EShine is the brand. I may swap it out for a daylight color but for now, the 3000k will suffice. These are 12" long, about 1/4" tall, and maybe 5/8" wide. These are also a gray/silver and black color combo which matches the stone gray interior. These lights are 12v and use a small barrel connector.
I used 2 small scraps of metal as a brace that locks down under the middle trim paneling. I think these were from some recessed lights that had some adapters for 5" cans. The lights had 3m double-sided tape which I used but I also ended up putting in 2 small screws since the tape wasn't liking the summer heat. To prevent the screws from digging into the headliner I cut all but 1/8" of the thread and hot glued the plastic insert which normally would go on the front of the light to hide the screws.
The metal catches under the rear trim panel and when you press that up it locks the entire thing into place.
The wire is just tucked behind the panel, routed up from the existing cargo light area.
Lastly the results. This was at dusk, maybe 8pm so it wasn't entirely dark but enough you can see the difference.
