Bluetooth has been working well in our 2011 XLE & volume adjusts easily during a call. However, the "beep" that sounds after pushing the steering wheel "talk" button for voice prompts has an unbearably loud volume & pitch. I dread pushing the talk button & try to cover my ears before the beep sounds (so much for hands-free). Is there a way to adjust the volume downward?
Yes. I don't recall how or if I did this, but I was just thinking today that the beep for voice commands was just a tad too soft for me today, so obviously we have different settings. Sorry I'm not more help, but at least now you know that it's possible and that instructions are probably buried in the owner's manuals somewhere.
· Premium Member
You can turn the beep on and off. I believe the beep volume tracks the voice volume. Our is not very loud.
After some trial & error, I found the fix --
The beep volume falls under what the manual calls "Guidance Volume"
Adjusting the beep volume concurrently adjusts the sound of the BT system's "voice"
On pg. 512 - the instructions are under the heading SYSTEM SETUP ITEMS AND OPERATION PROCEDURE / sub-heading is SETTING VOICE GUIDANCE VOLUME
As the manual notes, you can only access these System Setup Features by using the Tune/Scroll knob on the radio. I couldn't access these using the steering wheel commands.
By turning the Tune/Scroll knob, you can scroll through the options. Pressing the knob will choose that option. Once I got to the right adjustment option, I used the "Volume" knob on the radio to adjust the volume up or down. I turned the volume down to "1" = pure bliss.
Thanks for the input !
Thanks that was a big help
