Hello everyone! I will start this off with saying I am no mechanic so please forgive me if I have misstated something. I just like to try and fix things myself. Just thought I would post about the recent situation I had with my wife's sienna in hopes that it may help someone. The A/C over time started to blow warmer. The coldest it would get was around 70° f. (100° days) The gauge readings while running would be Low side 80 and High side 250. (Outside temp of ~100°) . The gauges would slowly equalize once the engine was stopped. This seemed like there was a restriction in the system so I replaced both expansion valves and the problem is now resolved.
(New vs. Old valve)
As you can see the old valve is quite dirty and visually appears to be partially stuck closed. (Front and rear valves looked the same). Not sure if this is a valid test or not but once removed I simply tried blowing through the small inlet and it was very restricted.
Expansion valves I ordered from RA:
DENSO 4752105 Rear
DENSO 4752106 Front
Expansion Valve locations: (NOTE: Refrigerant must be completely evacuated before doing this job)
Front - Just behind the intake manifold. I had to remove the windshield wipers, wiper assembly and the metal tray that the wiper assembly mounts to.
Rear - The entire rear passenger side panel has to be removed to gain access to the A/C blower assembly. See picture below.
(Valve is up under this assembly approx where the arrow is pointing)
I ended up replacing the valves myself which took a few hours and lots of patience. The rear valve is fairly easy to replace after removing the entire blower/evaporator assembly. I also managed to replace the front valve without having to remove the intake. After the valves were replaced I had the system vacuumed and recharged. Hope this helps someone out there.
Adding in post repair gauge readings: Low 43-45 High 225
Chris
(New vs. Old valve)
DENSO 4752105 Rear
DENSO 4752106 Front
Chris
