2011 le awd w/ tow prep-towing question
13530 Views 12 Replies 3 Participants Last post by  tekman741
New to the forum and owning a Sienna 2011 Le AWD w/ tow prep package(has 1200miles), always owned a Toyota but not a minivan. Bought a curt class III hitch with wiring harness. I want to tow a camper r vision bantam b19 dry 2687lbs with options 2880lbs I'm guessing with food cloths stuff.. 3100lbs. I live in Massachusetts(go bruins) and the law is if the trailer has brakes they must be connected otherwise any trailer over 3000lbs has to have brakes. So I definitely plan on installing the break system for the trailer. I also plan on having a wd hitch with sway bars.
My question is will the minivan be able to haul that load up and down 7% grades with out voiding my warranty or killing the tranny? Any thing I should install to help keep the vehicle in good order while towing. I called the maintenance dept where i bought the vehicle at and they where useless. I've seen some really good post here but nothing conclusive about warrenties and when a wds is needed. Does my 2011 6speed any better at towing than the gen II sienna?
Any input would be of great service.
1 - 13 of 13 Posts
That's only 220 lbs for any water (the water heater alone will have about 50 lb of water in it), plus propane, plus everything you take along. I would assume three or four times that weight allowance, which will take you close to the Sienna's 3500 lb trailer weight limit (which is okay... just a reality check).
Good. At 3000 lb the trailer is three times the weight at which Toyota requires brakes on the trailer... the legal requirement is essentially irrelevant, since Toyota and good sense require trailer brakes at a weight below the level that any state or province requires them.
Yes, that's what is meant by the towing capacity rating... assuming that you keep passenger and in-the-van cargo down to stay within the Gross Combined Weight Rating. 7% is a typical grade for the steeper parts of Rocky Mountain passes, and I have no problem with them with our 3000 lb trailer and lots of cargo in the van. I'm sure that this grade is within the conditions considered in the towing ratings.
In Massachusetts, those 7% grades must be pretty short (eastern mountains may have steep sides, but they're not tall by western standards) so a rig there will see less sustained high-load grade-climbing conditions than someone out here (I'm in Alberta).
I assume that the one additional ratio means a smaller speed change between gears, so the transmission can keep the engine closer to the desired speed - that's a good thing.
Thanks for your response.
As far as the transmission is concerned, I wouldn't think the current 6spd would be built any lesser than the previous generation 5spd, but the current V6 highlander still uses the 5 speed transmission with a tow rating of 5000lbs. Why wouldn't they use the newer 6spd in the highlander?
As indicated in recent discussion, the six-speed 3rd-gen Sienna uses a clutch-based AWD system which is different from the differential-based AWD system in the five-speed 2nd-gen Sienna... and the Highlander still uses the same system as the 2nd-gen Sienna. I suspect that Toyota does not have a six-speed available which is designed to work with the differential-based system (since the six-speeds are new and Toyota is moving away from differential-based AWD), and that the Highlander has kept the differential-based AWD system at the expense of foregoing the sixth gear.
Just my speculation...
update: So I have my new to me TT dry weight 2484lbs. I drove 50mile straight to the rv dealer who sold me my wd hitch and installed the trailer wiring, both did not work. Yes, I drove with no lights and a reg hitch with sway bar with a trailer weighing in at 2800lbs(the previous owner gave me a bunch of stuff). With that hitch the sag was noticeable, the rear was down about 2 1/2 inches and my head light pointed to the sky plus it bounced quite a bit. A scary situation... But the Sienna handle well, on the highway I avg 60mph and I live in central/western mass (Worcester area=very hilly). I went up an 8% grade that's about 1/2mile long and no issues rpm was just below 3000.
When i got to the rv dealer and they fixed my issues and installed a Blue Ox BW0550 wd hitch the Sienna sat level and then they adjusted it up a little for adding the max weight for the Sienna of 3500lbs. Man, what a HUGE difference.... I only noticed the weight going up and down hills plus no bounce.
I asked about air bags and their answer is yes it would help with clearance of the hitch but it does nothing to move the weight from the rear to the front like a properly adjusted wd hitch. They did say having both is overkill but it could not hurt having airbags but only if you have a wd hitch. Makes sense airbags lift your rear off the ground giving you more clearance but not distributing the weight and using the hitch as it was designed.
tekman741 said:
Yes, I drove with no lights and a reg hitch with sway bar with a trailer weighing in at 2800lbs(the previous owner gave me a bunch of stuff). With that hitch the sag was noticeable, the rear was down about 2 1/2 inches and my head light pointed to the sky plus it bounced quite a bit. A scary situation... But the Sienna handle well...
The Sienna has a ten-foot wheelbase. If the rear was down 2.5" and the front was up an inch, that's 3.5" over 120", or an angle of 1.7 degrees... not exactly pointing at the sky. Boosting the rear back up to normal height with air bags would both address this and stiffen the rear suspension for control.
Of course a WD system works to some extent, too.
Putting a couple of adults in the third row and some cargo behind them (with no trailer in tow) has the same effect... but there's no way to compensate for that with a WD system.
tekman741 said:
... then they adjusted it up a little for adding the max weight for the Sienna of 3500lbs.
A WD system adjustment has nothing to do with trailer weight; it only shifts load to compensate for the effect on axle loads of weight on the hitch... so there is no adjustment for a 3500 lb trailer. I note that the Blue Ox website and instructions refer to the capacity of their system entirely in hitch weight terms, not trailer weight. Did this mean adjusting for 525 lb of hitch weight (3500 x 15%)?
Why adjust the WD system for load that isn't there? That's over-application of the WD system, which reduces stability and can potentially overload the front axle.
Did the dealer adjust the WD system correctly, by checking axle loads or at least measuring front and rear ride height as per the WD system manufacturer's instructions? Unfortunately, the Blue Ox instructions for this aspect are terrible... I would suggest following the Equalizer or E2 instructions regarding the resulting ride height.
It is true that air bags do not shift load... but is there any need to shift load? Is the rear axle overloaded without WD? If the only problems (sag and lack of stiffness) are resolved by air bags, there is no need for a WD system.
What does the last part mean - which part do you mean by "hitch"? The hitch receiver is not designed specifically for WD use.
Point taken about the airbag. the dealer used measurements and used my max load weight of 3500lbs. Yes the blue ox is over kill but it's working quite well. Hitch I meant the lowest part from dragging.
Sorry if it seems that I am picking on this, but I don't understand what they did. Measurements can be of axle loads (drive over a scale) or ride height (measure from ground to fender opening), but in either case they are used to tune the WD adjustment to compensate as desired for the weight on the hitch (not the trailer's total weight). Having done that, how would the dealer "use" a planned max loaded weight... was the setup done with the trailer loaded up with ballast to 3500 lb? Did they "crank it up a notch" from the correct setting for the trailer to allow for a heavier load?
Sorry, still not getting it... I was wonder what the comment about "using the hitch as it was designed" meant. ??? Just that a WD system is designed to keep the low bits from dragging, perhaps? That's not really true; a WD system is to shift loads to avoid an overloaded rear axle, which does incidentally address sagging rear end problems.
It would be a big shock to all those commercial truckers running 40-ton (and much larger) tractor-trailer rigs out there that their air suspension systems are not appropriate, and they should be using some spring bars stuck onto their hitch to take the load off of the truck's rear axle(s). ;)
(For those who had not realized... fifth-wheel hitches could be built to use a WD system but none are, and even with conventional rear-mounted hitches for "tag" trailers heavy commercial and military rigs never use WD systems; WD is a recreational feature only).
Point is well thought out unfortunetly I am not as knowledgable so I'm trying to take in as much info as possible before sinking another $1000 +/- into the minivan to haul the camper. My goal is to use the local landfill scale for three measurements:
1) tow vehicle weight(sienna)
2) tow vehicle and trailer (both on the scale)
3) tow vehicle and trailer with only the tow vehicle on the scale=tongue weight.
I just went camping for the first time and the Sienna did just fine. It labored going up hills, as expected, but did just fine. It did seem to bounce a bit. Yes, Brian I know air bags. = lol
When the dealer adjusted the WD they set it as if the trailer was heavy (3500lbs). There is a set of directions that shows how to do it. So the WD works by shifting the weight as evenly as possible based on the measurements. The airbags would also do this and help with ground clearance. both help with sway along with trailer brakes. correct?
Good, but those scales are not very sensitive so the tongue weight (Sienna with trailer minus Sienna without trailer) will not be very accurate. Also, the WD system must be disconnected for this to work. To really know what's going on, that means three trips across scales which provide individual axle weights:
  • Sienna alone for tow vehicle weight and starting axle loads
  • Sienna and trailer without WD for trailer weight and trailer starting axle load
  • Sienna and trailer with WD connected for final axle loads
The scales which can't be arranged to give a number for each axle will work as planned for tongue weight and total weights.
If you want to get closer, the tongue weight can be measured directly at home with a suitable scale... for trailers with enough tongue weight to need WD, that's a high-capacity bathroom scale, a lever arrangement with a common scale, or a special trailer tongue scale (such as a Sherline).
Yes, there are directions... and they do not involve some calculation of over-adjustment for higher loads, and have nothing to do with trailer weight. They could hook up a heavier trailer, with some higher hitch weight which may be different from a heavier trailer that you might tow, and thus get settings which are wrong for you.
More likely they just cranked it up a notch from the setting which they thought would be correct for your actual trailer. They might have some "rule of thumb" which says how much load is transferred per notch or turn of the WD adjustment, so they can guess how much to crank it up, but the result in any case is too much load transfer with the lighter trailer tongue.
There is no clever design or adjustment of the WD system which can change the proportions of the load redistribution, only the total amount. If the distance between the tow vehicle's axles (the wheelbase, which is 3.0m or 120" for the Sienna) is equal to the distance from rear axle to the trailer axle, then it is like two people on a teeter-totter - the load transferred to each end (tug front axle and trailer axle) is equal. If one dimension is longer (and usually the rear axle to trailer axle will be longer than the wheelbase) then that end gets proportionately less load, like a person sitting further out on the teeter-totter who doesn't need to weigh as much as the person closer in on the other end. The proportions of the load distribution are entirely dependent on the length proportions of the wheelbase and distance to the trailer axle.
So, if the WD system is adjusted to add 150 lb to the front axle, and the trailer axle is 180" from the van's rear axle (1.5 times the wheelbase), then the trailer axle will get 100 lb added to it (150 lb / 1.5), for a total of 250 lb removed from the rear axle.
If by "as evenly as possible" you mean that the person doing the adjustment is trying to even out load on axles, take the vehicle away from them and find someone who knows what he is doing. ;) Correct adjustment is about counteracting unloading of the front axle and staying within all axle limits, not making anything equal.
Airbags do not change axle loads, they only make the suspension stiffer (so that it controls heavy loads better) and higher (to reduce sag). Yes, they would help with ground clearance (by lifting) and sway (with better control).
If the rear suspension height is changed with air bags, then the angle between trailer and van changes, so the WD springs are bent a different amount, so the load re-distribution is changed... so the WD system needs to be readjusted. The same thing goes for loading down the back of the van with cargo so it sits lower... that's another WD adjustment.
Trailer brakes are for stopping shorter and with better control, but they can be manually applied to control sway if it starts. I've never needed to use them that way.
see attached pic of sienna with wd any thoughts?
1 - 13 of 13 Posts
