2011 sienna.... compressor clutch not engaging
191 views 2 replies 1 participant last post by  S11sienna808
I change my ac compressor because stock compressor died. It was working amazing for about 2weeks then all of a sudden the AC light started to blink and it died. After wiggling some of the connections and check freon levels....the AC blinking light is now working fine on or off when pressed.
Butthe AC compressor does not kick on. I also noticed now the condenser fan does not turn on.
After thinking maybe i bought a dud cheapo Amazon compressor I decided to buy a better one and replaced the new compressor to newer compressor.
The ac compressor does not kick on. The HORRID model year 2011 Toyota sienna suck because it does not have a magnetic clutch relay. Or fuse.
Does anyone have tips or electrical check I can do.
I back pin the AC flow sensor and found 4.5v on the supply and ground was good.
I did notice the other harness by the AC magnetic clutch 3 prong triangle shape connector. Does not have any power when I back pin all three.
Please help thank you
