Greetings!
I have a 2011 Toyota Sienna 6 cylinder. For the past few weeks, I have had intermittent misfiring of the front bank of cylinders while getting up to speed on the highway.
Here are the symptoms:
When getting up to speed on the highway, going uphill, around 60-70 MPH and 3500 RPM (roughly), the flashing check engine light, ABS, and VSC lights come on and the van goes into limp mode. The vehicle also runs rough, as if it is going to stall. I am able to recreate the issue.
As soon as I restart the car, the check engine light goes off and the vehicle drives normally.
After running my OBD2 scanner, the following trouble codes were reported:
C1201: Engine Control System Malfunction
P0300: Random or Multiple Cylinder Misfire Detected
P0302: Cylinder 2 Misfire Detected
P0304: Cylinder 4 Misfire Detected
P0306: Cylinder 6 Misfire Detected
Steps I've taken so far:
The van has 110k miles on it, so I had our mechanic replace the coils, plugs, and intake plenum gaskets. All parts were OEM Denso. I hoped replacing the old plugs and coils would fix the issue but it did not...
To rule out electrical issues, I had the battery and alternator tested at two different auto stores. The scanner results indicated battery and alternator are good.
Before I take the car back in for more diagnosis, does anyone have suggestions as to what I might try next?
