Hi,
Just joined last night. I have a 2012 Sienna SE and saw another owner change his rear reflector on his Sienna to LED where it interchanges from being used as a break light to back-up light. I have not been able to find this anywhere, can someone help? Thanks!
Got mine through eBay. Just search " sienna rear reflector led." Wanted to use the third lights as reverse but ended up using them for turn signals, too much involved with wiring for reverse. Good luck!!
Reverse is not bad at all. Just need to splice wiring cause the one with those lights is too short. What I did is spliced reverse wire from left side next to taillight, then ran a wire along bottom jam to the right side. Spliced it there and ran along the pillar up to the top of the jam where there are grommets and wiring for a hatch. With some fish tape, like coat hanger wire, run it through rubber grommet with the rest of wiring and run your wire along rear window to ether side reverse light. I spliced mine at left side next to reverse bulb. It should be red/black positive. It is pretty simple, will probably spend an extra hour at the most, including taking all the plastic off.
