1 - 15 of 15 Posts
Hi,
Lately I've noticed the engine is very noisy, it almost sounds like a Chevy from the 90s. When standing outside of it, it doesn't sound smooth at all.
Lots of ticking and I can hear things going round and round... normally heard on older cars from my experience :)
It has 62,000 KM on it.
I'm also comparing it to my 2017 Nissan Pathfinder which is dead silent (especially compared to the Sienna).
Any ideas?
Thank-you.
Rattling sound would likely be loose exhaust shield, bang on the exhaust under the car trying to recreate the noise while the engine is cool.
If it's a squeaking or rotational sound, look around your belt area on the passenger side. Make sure everything looks smooth and there's not a lot of movement in the belt or pulleys.
Discussion Starter #4 (Edited)
I checked out under the hood while it was on, and it's definately the engine area on the left (while looking at the engine from the front).
It's a round spinning with silver shiny bolts on it, I think it's the fan belt pully thing, but it's so tight in there I could not tell for sure.
It's on the left of the engine, I always thought fan belts were on the front, but that was on my v8, it looks like this engine is sideways :p
Yes, it's a transverse mounted engine, with it's "front" facing the passenger's side fender. Most FWD-based vehicles have this arrangement. The sound? Still hard to say. Waterpump maybe. Idler pulley maybe. Does it change with the AC on or off?
That seems to looks like your water pump/AC/Alternator pulley. Couldn't see clearly with all those parts they cramped into that side of the engine😁. If you have a small long pipe/tube just place it near that pulley and listen to the noise. If you hear grinding sound, that means the pulley is going bad. But if you hear a howling sound then that's bad news - your Water Pump pulley bearings are bad. Try to zoom in on the video and observe and see if the pulley has any swaying while engine is running.
wrong answer; come on: would the guy mistake exhaust shield noise for engine noise??? give him a break;
also: the engine noise does not sound all that unusual; take it to the dealer and ask them if they think there is a problem;
The two-part reply was posted BEFORE the OP added the Youtube video with the sound and location. And the OP did state 'ticking' which is quite often heat shield expansion/movement.
As judge/jury/executioner, I'm going to accept the answer and award points for trying. ;)
1 - 15 of 15 Posts
