Even though you are in relatively flat area, I would not want to tow that trailer without brakes.
Also, the Air Lift and the WDH probably should not be used at the same time. The Air Lift only stiffens the springs to prevent rear end sag, but the WDH actually transfers weight off the back to get it to ride higher. You might get the hitch set first, then add a little air to stiffen, more than raise, the rear end.
