2016 Sienna LE tow package?
12K views 4 replies 2 participants last post by  fibber2
The main element of the tow prep package is an engine oil to water heat exchanger located just under the front exhaust manifold. It looks slightly different and is a bit harder to see on the Gen-III vans, but this is a composite I put together a few years ago based on a Gen-II van. If you have this accessory, you have the most important component.
Looks like Photobucket no longer allows imaging linking and this site won't allow me to attach a thumbnail right now. I'll try again later.
Reactions: Lar
The same engine is used, so the basic layout under the hood is pretty similar. But while you could easily see the top rim of the exchange unit just by looking down behind the radiator fan, you might need the aid of a flashlight and mirror. One day when I have a moment I should update this slide with pix from my new van.
I'd suggest finding a motor-head friend to help you look for this hardware under the hood.
Good luck with your new van and trailer!
Reactions: Lar
