Hi all. Just purchased a brand new 2016 8 passenger Sienna about 2 months ago with the intentions to be able to install a new stereo system that does not take up any useable space for people or crap. After taking apart the entire van to sound deaden it, I started planning on the equipment that I would install. The stereo would be installed in two stages, the interim phase and the final phase. During the interim phase, i'd install everything that is necessary to quickly upgrade the sound with some new equipment and stuff that I already have from past builds on other cars. For the final phase, i'll be constructing a hidden fiberglass sub box and a-pillar pods for 3-inch widebanders and AMT tweeters. Here is a list of equipment that I will be using during each phase.
Interim Phase
1. Peerless NE65W-04 2" Full Range Woofer
2. Helix 265G 6.5" woofers
3. JL Audio CP108LG-W3v3 Single 8W3v3 Ported box
4. OEM headunit
5. Rockford Fosgate 3sixty.3 DSP
6. Alpine KTP-445u 4 channel Amp 45watts x 4
7. Alpine MRV-500 Mono Amp 500watts x 1 at 2 ohms
Final Phase
1. Dayton Audio AMT Mini-8 Air Motion Transformer
2. Tang Band W3-1364SA 3" Bamboo Cone
3. Dayton Audio LW150-4 6" Low Profile
4. Image Dynamics ID8v3 dual 4 ohm 8-inch Sub
5. OEM headunit
6. Rockford Fosgate 3sixty.3 DSP
6. 2 Alpine KTP-445u 4 channel Amps 45watts x 4 for each; 1 for the AMT and 3-inch, 1 bridged for the Dayton 6-inch woofer
Now onto the build of the interim phase and some pics. I wanted to keep the OEM headunit because my wife, who mainly drives it to work likes the interface and setup of the OEM headunit. So I took a chance and gathered some measurements using the rockford 3xisty.3 OEM integration signal normalizing feature and found that the OEM unit didn't do too much in terms of equalizing the signal on the top and bottom octaves, but the equalization does change depending on the volume. You are able to turn the volume up to 51 before there is enough distortion for the 3sixty.3 to not be happy. Therefore, when setting up the 3sixty.3 I set the volume to 26 and went through the process. To get the signals from the OEM headunit to the 3sixty.3, I used the high level outputs and made a new cable with speed wire and some factory plug adaptors from metra and scosche.
I ran the speedwire down the center area, under the center console, and to underneath the drivers seat where I plan to house the rockford 3sixty.3 and 1 Alpine KTP-445u amp. I ran some 4 gauge power wire from the battery, across the engine bay, to a grommet behind the glove box, and then to under the passenger seat where the power distribution/fuse box is located. I installed the Alpine MRV-500 under the passenger seat, but not directly underneath because there wasn't enough room. I just let half the amp hang out and covered it with the carpet floor mat. The peerless 2-inch speaker is the exact same size as the OEM speaker up in the dash. I made a bracket using some delrin and made sure that the height was right in order for the dash speaker cover trim to seal against it. For the woofer in the door, I just used a cheap scosche plastic adaptor for the 6.5-inch helix woofer. The JL Audio 8-inch was installed right in front of the Alpine mono amp on the floor since my childs car seat is on that seat. No one will be sitting there, so no feet to worry about for now. Once I got everything working and tuned to my liking using an RTA and test discs, I was satisfied with the outcome. I can get all technical with how I did everything, but i'll spare you the reading. Overall, the sound is ok and is good enough for the interim term. The 2-inchers feel a little hollow/brassy at the moment. I'm going to try and build small enclosure for them to see if that'll make the sound more full. The bass from the JL is a little muddy and high strung. Def could be better. Only temporary, so I am ok with it. I've been listening to the system like this for about 2 weeks now.
Interim Phase
4. OEM headunit
Final Phase
5. OEM headunit
