21 - 25 of 25 Posts
Good call picking up the metal one. Shame they are getting cheaper switching more and more from metal. We have a metal one on our 2011. When our complimentary oil changes stopped, I had to use heat and long pipe over the breaker bar to get it off. The idiots at dealer over torqued it like crazy. Years later, when I went in for a steering issue, (thx goodness for extended warranty), I asked them to change it while I was there. Next time it was due, the same thing happened. I took it back to their service manager and made him go out and see what it took them to get it off while I was standing there. Their own guy had to use heat and breaker bar. I told them to look up the last guy who did it and fire his ass. No place for a person like that working on cars. Sorry, moral of the story is get a good torque wrench and always follow torque specs on that housing. You’ll thank yourself everytime you change it.
A really fruitful morning.
Took off the filter cap this morning, torque too much and heard crispy clear sound, I btoke it! Went to advanced auto get a metal cap, $26 after tax.
now this time it has both o ring pre installed.
Two lesson learned,
1. Original factory setting is plastic! Toyota tried every inch to save cost.
2. Dealer does not always do a proper job. That o ring should always be there.
View attachment 45583 View attachment 45584
You should always use the special wrench designed specifically for the type of filter. The wing you broke off is not designed to remove the filter by itself. The image is of a Ease2U available at Amazon for about $10.
Just curious, what sort of heat are you talking about and how did you or the tech apply it to the metal housing. If you run the van for 15-20 minutes, the housing gets very hot which should be.adequate for the housing to be twisted off with a breaker bar.
Sorry to read about the cracked plastic housing. I wished they had stayed with the metal housing instead of switching to the plastic housing. My 2011 and 2015 both comes with metal housing from factory. My 2020 however, comes with the plastic housing. First thing I did at 1000 miles was to replace the oil to get rid of any materials int he oil from the new engine and replaced the plastic one with the metal housing. Glad to hear that you were able to replace it with the metal housing and now have the proper o-rings in place.
which metal cap model did your 2020 get? this one?
Toyota 15620-31060
Toyota 15620-31060
I'm sorry it has been a while back and I don't have the order anymore to verify the item number. But from a search yes it does look like that is the correct one.
Note, you will need to reuse your small metal drain cap/plus on the plastic filter housing since I don't think it comes with that cap.
21 - 25 of 25 Posts
