1 - 14 of 14 Posts
Went to a fast lube place today for a 30K oil change. They said that the plastic oil filter cover was cracked and they had to get a newer style metal cover from Toyota. I had to pay $70 (their cost) for the part. Anyone else run into this issue?
Common, unfortunately. When Toyota went this route (disposable insert) over a decade ago, the housing was a metal alloy. A few years ago they went to polymer (plastic), and the complaints started rolling in across the Toyota universe.
The problem is common. The price is not.... Markup.
Of course the quicklube place wants $50 to change a cabin air filter that I bought for $9. Learn to do stuff yourself, or pay the man.
Discussion Starter #7
Thanks, Sinister2c. The one you link to won't fit the 2018, but I found that the OEM part from Toyota retails for $50.96. So this shop's cost was probably $35. I told them they made a few bucks, but lost a customer.
Does the 2018 use a different one? I thought they were all the same size when I changed oils for my 2011,2015, and 2020 Sienna.
You are probably correct. The part I located at Toyota Parts is actually the OEM plastic part - which has a different part number. I don't change my own oil anymore, so I'm not an expert on this stuff.
Amazon says it doesn't fit because it is listed as the plastic one. You need the metal one if you are going to replace. The plastic is garbage.
1 - 14 of 14 Posts
