1 - 8 of 8 Posts
I have a 18’ Sienna that just started making a noise when I shut the vehicle off. The closest thing i can describe it to is like someone tried to pass gas quietly but it ended up being louder than expected. Once its off, it almost sounds like air is being released from a hose or valve. Its hard to tell if its coming from under the air intake (in the back) or if its coming from the front. Can anyone help identify this problem?
If the A/C has been on, it may be the system equalizing pressure when it's first turned off. I have not heard that on ours, but we are usually making noise opening doors and grabbing stuff after shut off.
'07 XLE FWD, '18 XLE AWD
You're hearing the evap canister purge valve (more specifically, the solenoid that opens and closes that valve.) It's part of the emissions system. It's purpose is to allow fuel vapors to enter the evaporative canister, condensate back into liquid, and be returned to the fuel tank. It's often active in warm weather after you shut off the engine.
Discussion Starter · #7 ·
Is it hard to replace? would you happen to know if its near the back side of the engine?
1 - 8 of 8 Posts
