61 - 73 of 73 Posts
For those that have the 7 passenger set from Canada, does it allow the center compartment between the two front seats to slide back and forth? Does the lip on the floor mats block the sliding?
Thanks.
Thanks.
From what I've seen if you remove the carpet mats the center compartment clears the low profile of the all weather mats.
Those look much nicer than the previous ones. The old system for the rear mats was a nightmare. Anyone know if they make these for the Limited's 7 passenger captains chairs?
I went with Husky Liners in the front and Lloyds in the back on my limited premium. I like them a lot. The Lloyds have the tab to go under your track just like the OEM and cut like the OEM. I had ordered weather tech originally but sent them back. Husky has better coverage than weather tech and also has the nubs to keep better placement.
I ordered the mats from the ebay listing. They fit great! The only thing I was not sure of was the side strips. I did not use any of the under hooks or whatever you call it that came with the original carpets. I just have it laying there. Thank you Sienna Chat for finding this!
I dunno, they look okay I guess. The front mats look fine except like all other brands, except Husky, the driver side mat doesn't cover the foot rest on the left. This one looks like it doesn't even cover it partly like the WeatherTechs and others do. Husky's are still the best IMO since they do cover the foot rest almost completely.
The 2nd row looked good at first until I saw that it comes in so many pieces. At least the middle section didn't need to be two parts, and I can't see the purpose of having it come in 6 (or 4 if those very side pieces are trim pieces and not mats), seems like it would just shift around with use, or leak in between the pieces (I live in Seattle so paranoid about water/mud dripping onto the carpeted floor). Not sure why they can't connect (i.e. be attached) at the top end. Do they connect at the bottom end (behind the 2nd row)?
Since I don't slide the 2nd row seats almost ever, I use that WeatherTech "capital I" shaped single piece mat that covers the 2nd and 3rd row space, including the tracks so they stay clean. The problem of course is that you have to remove it when you want to slide the 2nd row seats forward, but I like the better floor protection. I think I would go with the Lloyd mats for the 2nd row if I slid the 2nd row seats regularly.
Hi, has anyone tried these in a 2014 Sienna?
I have a 2014 FWD Limited - 7 passenger.
From the seller description, it just says 2015 to 2019.
Thank you
ebay item # 123735501547
Has anyone been able to source these mats for an 8 passenger model? I see the p/n on the first post but you can't find it anywhere. Someone is trying to sell the 7 passenger floor mats for $999 on ebay which is absurd. I have the stock all weather mats on my 2017 and I hate them as they bunch up and slide around and are total junk.
I run Weathertechs on my 2015 SE, love them and the warranty. Had the fronts replaced due to sticky rubber after 2 years. Great product and made in USA. I have the three separate since I have 8 passenger version. The 7 passenger has the rear as one piece. Only issue is that you have to have middle seats set at a static position due to rails.
The set is like $270 on Amazon. https://amzn.to/2LY5gDg or on eBay https://ebay.to/2tlsuwJ. WT mats are basically listed price from all authorized dealers, not much price adjustments anywhere online.
I have a Maxliner trunk i got for like $90 on eBay. https://ebay.to/34krNAt
If you want to go cheaper, the Maxliner are basically chinese copies of Weathertech, the are priced about 20% less. you can get a whole set with trunk for cost of passenger mats from WT. https://amzn.to/35mdTPH
If you really want to go low end chinese copies, there are some sets on eBay for as low as $190. Cant comment on quality but looks like they took WTs and carbon copied them. https://ebay.to/2EeEOkv
61 - 73 of 73 Posts
