Where will the device be installed? Engine compartment? If so, there’s a couple of hots in the fuse box unused. Just connect a female My concern is how to run the wire out.
[/QUOT
it will be the aftermarket digital rear view mirror, so I’m looking for the fuse box either on the driver side or passenger side. Thanks!Where will the device be installed? Engine compartment? If so, there’s a couple of hots in the fuse box unused. Just connect a female My concern is how to run the wire out.
There’s a fuse box on the driver side, nearby behind the OBD port. There’s already a standard wire harness in the rear view mirror. There’s a discussion topic, search for dash cam, or something similar. Though not sure if it’s “constant on.”
My concern on connecting a device that’s always on, it would drain the battery. There’s a tendency for the 12v batt to drain quickly.
This happened to me. With the vehicle in ACC mode, it drained 5 minutes into the second 20 min cycle. I was only listening to the radio.
There’s too much electronics drawing current.
View attachment 63004There’s a fuse box on the driver side, nearby behind the OBD port. There’s already a standard wire harness in the rear view mirror. There’s a discussion topic, search for dash cam, or something similar. Though not sure if it’s “constant on.”
Someone pushed a shopping cart really hard to the back of my vehicle, luckily I have a rear bumper guard installed. It still left a scratch on the black bumper guard. From that moment I really wanted to have some sort of monitor device.Agreed - I wouldn't want an always-on device. Maybe look for a solution with a battery pack, if you're that worried. (like a battery powered security camera - tons of options now-a-days)
What will you do if you catch a _ attempt, though? Insurance covers theft and damage. Looking for police data? Vigilante?
Never seemed worth the hassle for me.
Thank you! Do you have a link to the original post/discussion?There’s already a harness up above the overhead console that is for the factory dashcam. It has ground, constant 12V and switched 12V. Yank the overhead console down at the front of the van and tilt it down from the backside.
2023 25
Here you go:Thank you! Do you have a link to the original post/discussion?
