141 - 160 of 160 Posts
Nice. When I search for wheels that size and offset, this is one of the only choices that I find.
Have you noticed any mud spray that isn't caught inside the wheel well, with the different offset a bit farther outboard?
How about any changes in braking distances with the beefier tires?
Open country all-terrain’s from Les Schwab
245/65R 17. Black rhinoUnit wheels, 17 X8 with 15 mm positive offset. Fits perfectly into real well without rubbing
I love the look of your van. I think we have a very similar set-up. View attachment 45572
Inko
With that trailer and your lifted sienna AWD, it looks like you’re good to go. I’m sure that’s a very convenient set up.
I think it was A photo of your sienna with black rhino boxer wheels that helped me narrowed my search. Did you get the 15mm positive offset or did you opted for 35 mm positive offset and ran 1inch spacers from Journeys offroad.?
I switched to 15mm offset on the new wheels so I wouldn’t have to use spacers. I’m uncertain about safety issues with them, but almost all major tire shops like LES schwabb won’t work with spacers. I got the black rhino Unit wheels at 15mm offset and they have been working well. 3000 miles and no issues.
45694
45695
riverrat
I’ve taken the sienna set up with new wheels and tires to Death Valley twice now. Probably a good 20-30 miles of dirt and gravel roads each time. No issues with gravel spit and no rock scratches on door or rear fenders. I’ll try to send you a photo of the dirt pattern on my sienna.
the 15mm offset on new wheels pushes the tires out to just the edge of fender well. The stock toyota rims are at 45mm offset so they are very recessed into wheel well. I also wanted to take full advantage of a wider wheel stance because of the lift, to counter balance any topHeavy side effects etc
the open country tires are impressive. VERY VERY QUIET on pavement., which is 90% of the trip. But good all terrain performance on dirt and gravel. I don’t do anything outrageous off trail w sienna.
No change in braking performance. I have the Bosch rotors in front and stock in rear. Upgraded pads all around. No brake fading. In addition, no loss of power either with larger tire diameter. My new tires are 29.2 inches. Stock set up was 27.5 inches I believe. They say speedometer reading can be off 5 miles per hour. I compared car speedometer reading w gps and street radar. Same readings.
Here Are photos w dirt spray pattern w new wheels and tires:
45696
45697
45698
SkiShootClimb75, Which make and model (and parts) did you use for the front-most cross bars over the driver and front passenger? I hate all that wasted roof real-estate.
Also, thanks for all the detailed responses - it goes a long way in demystifying the process.
DoubleO
I had the guys at RACK N ROAD outfitter in Sacramento CA custom install the front bar for me. It is a universal foot drilled directly into the roof and can accommodate either a Yakima or Thule foot pending what brand u want. The cross bar is either Yakima or Thule whisper aero bar that comes out to edge on front doors. I didn’t want head injury getting in and out of sienna w sienna at stock non-lifted height. But now with the 3.5 inch lift, the longer bars will not be of any issues. the front bar is a must if you want to maximize roof Realestate. Make sure you do a test fitment run with the front bar position before drilling. The front bar will sit pretty low with most of the existing feet on the market and will not allow your sunroof to open. I would look for the tallest foot for the front bar.
i used long Thule bars for the back. Incorporated into the factory luggage roof rack. The front set up is designed for long skis and Snowbaords/bikes is needed. The rear bars are closed together for my daughters boards and skis. They also accommodate snow shoes when we go snow camping/trekking etc. I don’t put anything that can fly around inside in the back. I also used rhino rack MaxTraxx adapters to mount a side mounted ski carrier for quick carry of poles or a single board when I’m on my own. Very convenient.
I’ve had that system for on for 5+ years. No issues. 185,000 miles without any rattling or failure. Gas mileage efficiency is same. Factory says 18.5 miles per gallon. My cars reader says 17.5. Not too bad.
45699
45700
45701
45702
DoubleO
View attachment 45700 View attachment 45701 View attachment 45702
No worries about efforts in getting as much details as I can for anyone researching. It saves headaches when you can get the story and the pictures to help make decisions. Less time on-line. More time on the slopes and the water.
I do recommend changing the wheels and tires if the funds are available. Stock wheels are 18x7 with 45mm positive offset. I changed to 17x8 wheels with 15mm offset. I also added 245/65R 17 Open Country all terrain tires from LES SCHWAB. The lower offset helps to push the wheel out by 1-1.5 inches so it helps with getting the sienna to a wider stance, reduce any top heavy sensation. The 17 inch tires give a softer ride. Feels way more solid.
Hey SSC75...another q for you. I'm planning to have Journeys install their lift kit this fall when I'm in AZ for a river trip. After we bought our 2015 AWD Limited, I swapped the stock 18" wheels & run-flats for aftermarket 17" wheels that were included in the deal, and new 235/65R/17 Michelin X-Ice snow tires. That's what's on the Sienna now. They work great, especially in snow but also ride way better than the run flats. But I'm not sure what offset they are, guessing probably same as stock wheels.
For spring/summer/fall use, I'm thinking of selling the stock 18" wheels and run flats, and buying some 17" wheels in the size you suggest- 17x8 w/15mm offset. Still doing homework on what to buy for spring/summer/fall tires for use here in western Oregon, but will probably get the same size 235/65R/17. (I may bump the width up to 245.)
My question to you is: do you think the 15mm offset wheels and the 235/65R/17 tires would work without rubbing before I get the Journeys lift installed?
According to this fitment calculator, you should be fine before adding the JOR lift. Just make sure that the power sliding doors will still cleat a 32.7mm poke. There isn't much room when they open.
45795
Cool, thanks Mitchollow!
Any chance you could give a link to the calculator you used?
Journeys lift is sort of on the back burner right now, in light of current events, but still tentatively planned
Fitment calculator:
With regards to current events, I ordered my JOR kit a few days ago and it arrived today. Went down to the Toyota dealership and talked to their service department about doing the job. They're are an "essential business" and it's a ghost town there. Good time to schedule work if you can. Also stay 6 feet away from all people at all times.
Fitment calculator:
I was planning to have Journeys install their kit in my Sienna when I was in Arizona this coming October, but that trip is up in the air right now. Keep us posted on how your install goes, and your impressions of how your Sienna handles afterwards!
By adding a lift package to car does that do anything to the warranty?
Ordinarily, one would assume so and the answer is probably "usually, yes". But check out this video and the comments that go along with it. Shows the Toyota dealer in Bend, Oregon installing the Journeys lift kit on a 2019 Sienna. The comments indicate that they are still willing to warranty the vehicle after the lift is installed.
Some things to keep in mind though: 1) Unless a dealer installs the kit themselves, they're unlikely to warranty the work or the vehicle that the kit is installed on. 2) The Journeys kit appears to be well-engineered and those who have it (I don't) indicate that it doesn't influence handling as much as you might think. But it still does change the geometry of certain suspension parts, and it remains to be seen if that reduces the life of some of those components over 100s of thousands of miles. The Toyota warranty ends while a Sienna still has tons of life left in it.
FWIW, I'm planning to have Journeys install their kit in my 2015 AWD Limited this fall, if this C-19 crisis abates by that time..
Hi Inko
Portland is beautiful. We go up to Hoodriver every summer to sail the Gorge. Most always epic.
No, I’m down in the Stockton-Sacramento Region. Lots to do here as well, but we always look forward to our times in HoodRiver.
Hi Inko
Hi SkiShootClimb75. Your sienna looks good! I’m from Sac area too. Can we meet up one day? I like to see you sienna. I’m planning to do some mode on my 19 sienna awd just don’t know where to go and start. I called a few 4x4 shop in the area and they just laugh at me.
Jab
I’m not surprised you had a few raised eyebrows regarding lifting your sienna. Especially if you don’t have a premise lift kit specific for it. 4-wheels Parts and Valley truck Accessories in stockton CA may be able to install the lift kit for you. At least they said yes to me a year ago, but I had the Journeys off-road info so they can check it out. The guy that did mine was a private shop in sac. Let me know what modifications you’re trying to do and I can try to give you all info that I have etc. Il
Most of these shops are not familiar with the Journeys kit. You can check out my sienna if you are uncertain about the lift. My only word of caution is to not change out the toyota OEM cv axles as the after markets ones are less true and can cause slight vibrations.
45848
Jab
Jab
Yes! I love to. Can we meet up Tuesday afternoon between 3-4 if that works for you? How did you put your led fog lights? Did you also change your sway bar link? I have read some other person comment about there sway bar link. How many miles you put after the lift? Any issues now? Hows your traini?Did you use any spacer on your wheel?
L
Jab
no change in linkage rods for sway bars, that I’m aware of. Unless it came with the Journeys off road kit. You can verify this with Journeys if needed.
Fog lights are LED from Morimoto, ordered from CarID.com. I think they are just plug and play. They come intact in housing. Not bulbs.
I have approximately 8-9k miles after lift kit install. The one issue was a slight vibration on acceleration which was significantly improved after driveshaft support bearings were changed or replaced per mechanic and alsorecommended byJourneys. My other problem was the seal on the new right front cv axle: brand new aftermarket axles were installed as recommended because my car had 180k+ miles on it. In hindsight, I should have left the OEM axles in place. The aftermarket axle on passenger side has rough surface where the seal needs to make 100% contact to avoid leaks. I just had them replace the seals, to OEM Toyota axle seals. Keeping fingers crossed. New axles from Toyota hard to get forAWD models.
No issues w transmission as of yet. My
Tranny was a little rough between 1st to 2nd but that was way before the lift kit. I think it was just getting old. I went into this lift knowing potential pitfalls. Wanted to test out for myself, as I didn’t want to buy a new sienna and then damage it with lift kit and alterations on a brand new car. I’m gonna try and get to 250k miles and see. By that time I may have to trade in anyway. So far I’m happy with the lift. The goal for me was to have a minivan that we use often , but lose the hesitation of getting on rougher dirt roads. Even w lift kit, sienna not designEd to handle more than what I described. At least not without seriously beating it up.
Spacers: I tested out the 1 inch spacers from Journeys. They push the wheels out flushed with fender. After a bunch of test mounts with guys at les Schwab, the final calculation was going to a 15mm positive offset from the stock wheels 45mm positive offset to get the wheels to be flushed with fender. So I purchased wheels w 15+ offset and removed the spacers. A lot of people don’t like the spacers. Especially tire shops. I think spacers use is ok, but if you can get away without them, it’s maybe a little safer.
Do whatever you can first. And I can try to get more info for you as much as I can. Hold off on meeting for a while until all of this virus panic is over. The shop and mechanic who installed my lift is in Sacramento, but did it as a favor as it’s not something they want to do regularly. If you have Journeys info in hand, you can definitely get 4-wheels parts or any truck accessories shop to install.
