1 - 8 of 8 Posts
So I just saw the rumors that Toyota is looking to drop the v8 from the line up and go with a v6 hybrid turbo for the tundra. MAN!!! finally!!! how long will it take before they finally get a clue and put that 3.5L hybrid turbo into the sienna? I would for sure upgrade my 2015 Limited Premium AWD for a 3.5L turbo in a sienna. Come on Toyota, stop waiting a decade beyond when you should have come out with something to finally deliver what the market actually wants today.
By the way, while we are at it, please for the love of it... bring back removable second row seats. We don't need the extra airbags or whatever you think was awesome enough to kill the removable seats. I'd rather go Honda than compromise the removable seats. I do enjoy the idea of a 4cyl prime in the sienna, but the battery needs to be able to do 100 miles on EV alone (but a turbo 6cyl beats all, that is what will move the needle). I NEED BOOST!
While they don’t already have the powertrain in their lineup, I wish the Sienna had a 4-cylinder turbo hybrid powertrain. A bit more power than the gen4 has now along with the ease of maintenance of a 4 over a transverse V6.
I think that is what all the posts lamenting the 4-cylinder fail to mention as an upside. They all mention the better mpg, but a transverse 4 is a lot easier to work on (= less $) than a transverse V6 (no rear spark plugs!).
-Mike
^this^
I don't like FWD V6s, turbo or otherwise, because of the difficulty in doing almost any kind of maintenance or repairs on a transversely mounted V engine. It's too difficult to reach anything on the firewall-side of the engine bank. Besides that, small displacement turbo 4s are making amazing power. FCAs new turbo-4 hybrid for the Wrangler makes 375 hp and 470 lb-ft of torque. The 2.0L engine alone makes 270 hp and 295 lb-ft of torque.
After driving the hybrid Sienna, I'm coming around to the NA four. The layout is very maintenance friendly with good room to reach most everything and the engine has plenty of shove. My biggest complaint is the heavy obsolete NiMH traction battery and the pb-acid battery in the back. All the batteries should be Li-Ion. They could have saved at least 100 lbs by using modern battery technology.
Why not make your own turbo kit? Or do the HKS Supercharger on the 2GRFE 3.5L engine. If you want it, only thing holding you back is $$$$.
2021 Sienna Platinum AWD
I found the below in a 2018 article on the subject of Li-Ion vs. NiMH.
On the other hand, Toyota’s all-wheel-drive hybrids, like the 2019 Toyota Prius AWD-e introduced last week at LA, will for the foreseeable future use NiMH—because it can withstand extreme cold far better, and perform better in the cold temps where you’d expect an AWD vehicle to be used.
Well, one pretty good reason not to do that is it voids the powertrain warranty.
They make superchargers for the sienna v6. Lotus uses those engines and supercharges them to get 400hp in their Evora. It is a very capable engine.
Engine itself isn't the issue - it's very capable completely untouched..
One reason NOT to do those superchargers is bad design. Lower intake manifold is not free flowing like standard 2GRFE engine and the engine limits power due to knock from high IATs. To do that 1320 supercharger properly, you need a good plate w2a intercooler. When they introduced the 1900 at least the figured that out and added a w2a system...but who has that kind of $13k for a supercharged sienna. Do a proper custom turbo kit - it'll make more power and cost less.
Sent from my SM-G986U using Tapatalk
Discussion Starter #8
That and a CARB / EO certification come vehicle emissions/inspection time.
I'm not against modding, I have a FBO 2008 335xi sedan that puts down 450 awhp to the wheel (stock was 300hp motor).
I also had a fully built '92 eclipse GSX awd turbo as a kid, nothing was stock on it... kept it till 2016 and sold it with 250k miles and still boosting!
1 - 8 of 8 Posts
