I picked up a NextBase 622GW with their hardwire kit and was able to get it installed and wired into the roof console plug for the OEM dash cam. It did require some minor modification of the hardwire kit but beyond that it was super easy. The entire install was about 30 minutes. Check out the OEM instructions for good pictures on how that process works.
Here is my install in photos:
(continued in next post due to 10 attachment limit)
- Pull down roof console. This required hands on both sides pulling straight down, it is just plastic clips that snap out. It was more force than I expected but nothing broke.
- Informational: The wires in the harness are Ground - White w/ Black Stripe, Red - 12V when ignition on, Black - 12V Always On. The white cover on the OEM wiring harness pops off for easier testing access.
- A 2.54mm Pitch 5 Pin Housing Connector fits perfectly into the OEM wiring harness. So I cut the red and black wires on the NextBase harness, crimped two female ends on and inserted Red into position 1 (12V always on) and Black into 4 (Ground). If you want to power the camera only when the ignition is on push the Red wire into position 2.
- Insert into the OEM harness, it is a snug fit, watch for the blue LED on the power converter on the harness. I used some electrical tape to keep it all in place.
