1 - 20 of 60 Posts
Got tired of driving around with amount of rear squat and lights blinding everyone when fully loaded. The rear squat really made the handling feel very unstable.
Installed adjustable rear airbags to level out the van. Set it at about 36 psi which leveled it out pretty well (3 kids in the 2nd row, 3rd row folded down packed with camping gear... and 5 bikes). Took it on a trip to the Catskills last week and what a HUGE difference! You almost feel like you aren't carrying any load. Sway is minimized, Steering feels predictable and stable. The only indication that you have that you are carrying the weight is when you slow down... The under powered brakes in our Siennas quickly remind you that you are carrying weight!
I installed the schader valve in the jack/tool kit area and set to 5 psi with no load.
Purchased the kit here if anyone is interested...
http://www.amazon.com/gp/product/B000CFS028?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00
I bought used lease return 2011 last year, did the same Air Lift install with Schrader in existing fender weld alignment hole (no drilling) and set at 20 PSI. My daughter immediately bought a 2015 and got the Air Lift for Christmas, set theirs at 25 PSI. Air Lift maximum pressure recommendation is 35 PSI, but system volume is small, so use combo fill/gauge or real small compressor. eTrailer has great 15 min install video on youtube with before/after, under side camera views. Be sure to warm plastic tube ends in hot water before connecting to tee fittings.
Air springs work like progressive wound springs, work like shock absorbers, and when linked together act like a pneumatic sway bar. I've own/modified autos for fifty years and this is the best cost/benefit install i've ever done.....HIGHLY RECOMMENDED MOD !
Was thinking of doing this mod. My van has 20x10.5 with 275/40 on stock height and with 7 passengers it rubs on turns and bumps. You think this will help stop the rubbing? How easy was the install?
This really keeps the rear from sagging, keeping the van level and more stable under weight. I'm not sure, but if you're not rubbing w/o the passengers... then it might.
It's really easy to install...
Bought a set over the summer but haven't got to installing it yet. Glad they work. Have you tried towing a trailer with it?
Watch the install video several times and remember to slip the spring clip over the hose before making a connection....
and to use CUP OF VERY HOT WATER to make expanding the tube over the fittings easy....
i located my fill valve in existing fender well alignment hole inside passenger jack storage.....
punched (not slit) hole in existing rubber drain plug to get from under van to well....
DO NOT USE HIGH VOLUME/PRESSURE FILL....do not overfill 35 psi max....enjoy !
Install seems simple enough. Would this help the swaying of the van on turns? I just feel like a giant boat when taking turns sometimes. Thanks for the feedbacks.
Yes, body roll is significantly reduced. The typical install has both bags fed by one valve, I installed two separate valves to help improve handing even more. This will prevent air moving from one side to the other during turns, which I think would cause more roll.
You guessed wrong....connecting the bags with a TEE fitting and single fill valve acts like a pneumatic sway bar....
as you compress one side, it transfers pressure to the other lowering the lifted wheel....
most coil springs are linear compression, air springs are progressive compression AND dampening....
thus the transferred pressure makes the spring/wheel on the side of the vehicle that is highest put even more pressure downward, and raising that side even further. Squeeze one bag, the other gets more pressure.
thus increasing roll...
hence, 2 fill valves.
I have BC coilovers and found a smaller airlift bags 4"x4". The only thing that I have to do is cut the black spacers in half to make it thinner.
May i ask how long was the install for everyone? I have a sloped driveway so i'll have to borrow a friend's and need to plan out the time required.
Discussion Starter · #17 ·
Should definitely take you under an hour, it's not really that difficult. GL
Please let me know how install goes. Also let us know how u like them. I'm deciding if I should get these for a 1000 mile family trip. Thanks
That's not how they work
Installed May 2008, August 2014 on 2006 Limited, 100,000 miles on 1st set of bags.
1 - 20 of 60 Posts
