I have a new 17 Sienna SE and want to be able to remove the center console when carrying long items, there are two screws inside at the rear of the console but I don't see the front screws, I'm wondering if they underneath the vehicle? I fly very large RC model aircraft and will need to be able to remove the console when I carry the larger models. I have a Honda Odyssey that has a flip down tray so it's really easy for the task, but eventually I will use the Sienna for the large aircraft as the Honda is getting up there in mileage.
I can confirm that the 2017 are the same as all of the consoles back several years. The rear screws go all the way through the floor body to the outside so keep that in mind if you leave them out for very long. Also, a friend of mine broke one of his rear screws off when removing his 2014 console a couple of months ago. I recommend replacing them with stainless it you are going to the trouble to remove them.
Cheers
