1 - 8 of 8 Posts
Check that the cable you are using is a good quality (OEM) data cable and not just a charging cable. Also make sure you are plugging in to the correct USB port. The only port on the Sienna that has a data connection to the head unit is the one in front of the gear shifter on the dash. The center console and all the rear ports are charge only.
1 - 8 of 8 Posts
