Your owner's manual should tell you how much fluid the two marks represent.
You say above the pan. Do you mean the transmission pan gasket? Not much to repair that. Might just be a few bolts not tightened.
How big,bad is the leak you see?
Seepage, or a puddle on the ground? Is everything downwind of the source of the leak wet with fluid?
If it is seepage, just add fluid as needed. $35,000 can buy a lot of ATF.
