1 - 3 of 3 Posts
I recall that in one of SiennaClub's forum someone indicated that he has replaced the internal mirror with an OEM one that includes a hidden screen for backup camera. Hopefully he can post more info here
I have thought I just buying the aftermarket rear view mirror (Fry's electronics) ~$100 with the screen built in (I think 3" or so), but it looks too small. :-\
Another option was just to replace the whole stereo with a double din one and add a reverse camera.
Here's a sample, but this one is 5.8" for $180, from savv for about $180
I need instructions on how to wire an aftermarket Audiovox backup mirror. I got it working but the green LED seems to always be on. I wired it into the overhead counsel with the map lights. I must have used a wire that is always on causing the van battery to die after 3 days. I also need instructions on how to remove the counsel. I've removed the 2 torx screws. I need to know how it is clipped in so I don't break it when I remove it. I've attached some pictures. Any help you can provide would be appreciated.
1 - 3 of 3 Posts
