1 - 13 of 13 Posts
Hi! My Toyota Sienna 2018 awd build has a battery problem... and I am curious if this is a common issue or not. My battery dies within 1 to 2 days if I do not drive, it is a deep cycle yellow top optima. I have had this battery for less than a year and it’s pretty much shot already!
I am wondering if this is a common minivan thing because of all the technology like the AWD etc., things like that constantly drawing power or if I just happened to get a bad battery from the start??
I got the battery tested a couple months ago and it tested normal, But now when it was tested the cold cranking amps are very low.
So, does anyone else with a minivan conversion of this issue? Or any other types of vans? I am wondering if this is going to be a chronic thing or not and if I need to change vehicles. I’m hoping I just got a bad battery from the start!
I apologize if this was confusing post, let me know what you all think! Thanks!!!!
Also as far as we area aware there’s nothing wrong with the vehicle otherwise!
If you have already gone through the process of ensuring that the Van does not have a paraditic draw then it is very likely a bad battety. Batteries, even expensive ones, can fail much sooner than their rated life and can occasionally be a miss. If you google Optima batteries, a lot of folks have experience similar to yours.
I have been running the same Optima YellowTop (Group 35D) which is in its 6th year now (knock on wood) and it's been rock solid.
If the battery is bad as per testing then you should have yours replaced for free under the 3 year free replacement warranty
I agree, probably a bad battery. I have left ours for a week or two with no problems. Some of the electronics goes into low power mode or shuts off after a week to reduce battery discharge. Good for long term parking at an airport or with the current virus restrictions.
Hi ! Thank you so much for your detailed reply, that’s really helpful. I bet you are right. However, I realize I forgot to share that during these times when it dies the keys including the key fob or left in the vehicle (as I am living and sleeping in this van). I have heard from a few people that the fobs sometimes activate the cars brain in a matter of speaking, what do you think about that for drawing power? Thanks so much for all your help!
I think you both are right! that’s good to know about the electronics shutting off. However I realize that my situation is probably more complicated, considering I’m sleeping/living in this van — therefore the keys including the key fob are in the van all the time. I’ve heard from some people that that can sometimes draw power, have you heard about this before?
Thanks so much again!
Discussion Starter · #6 ·
also that’s incredible about your Optima! I will definitely look into getting mine replaced ASAP.
Did you check for parasitic draw?
Get an ammeter and put it in series while the battery negative is hooked up.
Shut and lock the car
Gently remove the negative terminal
Wait 15+ minutes, the current draw will drop as everything goes to sleep
The draw will never go to zero because you still have an alarm system. But it should be like, 5-10 milliamps. If it's a lot more than that, several hundredths to a tenth of an amp, then you have a parasitic draw
Unplug fuses until it drops.
It could be a short to ground, but it could also be a computer that refuses to go to sleep
Page 145 in owners manual - looks like power is reduced for battery drain:
3-2. Opening, closing and locking the doors 145
Operation of each component
■Battery-saving function
In the following circumstances, the entry function is disabled in order to prevent
the vehicle battery from discharging and the electronic key battery from
discharging.
●When the entry function has not been used for 5 days or more
●When the electronic key has been left within approximately 6 ft. (2 m) of the
vehicle for 10 minutes or more
●If the entry function has not been used for 14 days or more, the vehicle cannot
be unlocked by a door other than the driver’s door. To unlock the vehicle,
grip the driver’s door handle or use the wireless remote control or the
mechanical key.
The system will resume operation when...
●The vehicle is locked using the lock sensor when carrying the electronic key
on your person.
●The vehicle is locked/unlocked using the wireless remote control. (→P. 111)
●The vehicle is locked/unlocked using the mechanical key. (→P. 503)
■Conditions affecting operation
→P. 119
__
Scientific method. You know the battery is bad, why? Have you had situations that drained down the battery more than 3 different times. Regular Battery's, loose significant life span going bellow 50 %. This is why the alternator alway's keeps it charged for starting. When you start, immediately check battery with volt meter. 12.3-12.6 before start ( since your living in it maybe lower ( door's and windows more often when parked and off) When you park after driving what's your battery level. Back to the start sequence, you should see volt meter read 13-14.5 when first starting. This tells you your alternator is functioning. " If " your not driving daily where your camped is your battery loosing power below 12? If so, how long does it take for the battery to drop? ( a quick drop would indicate faulty battery) a slower drop would lean towards your camping / user style. Are your daytime running light's on? If so, and you climb in back without exiting driver door and closing it daytime running light wound go off automatically. Also, you can disconnect negative and see if drain down time frames change with battery just sitting. As mentioned above by berninicaco, If your loosing power and your confident it's not user style/error look for the parasitic loads/draw. Turn off auto dome function and keep doors closed. I've heard some complaint's about people leaving side doors open and killing their battery. Try to figure out the cause before committing to another battery and possibly killing that one too. Accessories? Are you using the 12v/115v in the back a bunch? If the car has had body work sometimes ground wires accidently aren't proper? all thing to look at before committing. I do love my little micro battery jumper for both additional cell charging and emergency self jump starts( about the same size as a cd case). good luck
Toyota has anticipated the case that you leave a key inside the van by going to a battery saving mode after a set time. Your situation is either a bad battery or parasitic draw. Parasitic draw is the most likely problem. This is a conversion van so there’s extra electronic equipment added that may be the problem. Replace the battery-hopefully under warranty and take the van to be tested or DIY test for parasitic draw. Testing is not easy or fast but it can be done. If you attempt DIY approach then find the FordTechMakuloco parasitic draw YouTube- it’s the best I’ve seen.
While sitting, my 89 Olds battery took a week to die. I removed one of the battery terminal wires and placed a small 12v bulb between the battery post and the terminal wire. If It dimly glows the drain is too much. I started pulling fuses and disconnecting systems. Zeroing in on the drain til the light went out. In my case the drain was a fault in the radio memory but in your case I'd suspect something bigger like a bad diode in the alternator. Good luck
Fixed the Olds drain fifteen years ago. Still drive it.
Did you put in an extra coach battery? Have a battery isolator for that?
Many things can drain power. Each time you open and close a sliding door the motor runs to shut the door. I've turned off the auto open close. I also try to shut the door with enough momentum the power motor doesn't have to work to close the door. When the battery gets low you can hear the difference in the motor closing the door. I have my interior lights off always—switch on dash turned to off. The only light to come on with a door open is the front door light. I've also discovered my Dometic fridge draws two watts always. Even with the power button turned off. I installed a battery monitor when I installed coach batteries—that's how I discovered the fridge power draw. Camped for days can drain the battery with the daily opening and closing of the doors...
And who said an old dog cannot learn new tricks - thanks everyone!!! Just had my car windows tinted - CA Sun, ya know...and the tint shop said my car battery died. Well, between not driving it for a week, and then the tint shop ran the engine and opening and closing doors for over two hours, Yeah, it died. The tint shop recharged my battery and let me know "there is something wrong with your car". I told them that their tint job was excellent, to stick to that.
1 - 13 of 13 Posts
