1 - 2 of 2 Posts
· Moderator
50735
Amazon Prime Day 2021 has arrived (June 21st and 22nd), and once again we’ve been combing through the lists of automotive deals. Much like previous years there’s a lot to sift through, and with all things automotive, not everything that’s cheap is worth spending money on. The team from Autoguide.com has taken a deep dive into this year’s offerings, and has filtered them into key automotive parts/accessories/etc categories.
As always, Amazon isn’t really a resource when it comes to performance upgrades, but it does contain a wide range of maintenance items and accessories. We’re talking things like lighting, car covers, battery tenders, diagnostic scanners, wiper blades, and other similar items required to keep your car in proper running order. Amazon also carries a decent range of tools for anyone who spends time tackling DIY projects (whether upgrades or otherwise). These can be from bargain no-name brands, or also reasonable quality ones like Tekton, Stanley, and others.
As it stands there are a ton of deals and discounts that have already gone live on Amazon already, and more will be added throughout the balance of the next two days. We’ll be doing our best to keep this post updated with the best deals that are geared towards our fellow auto enthusiasts.
As thorough as we can be, there’s no doubt something here or there that slipped past us as well. What deals have you found? Was there something noteworthy that we missed out on? Share the link in the comments below so your fellow forum members don’t miss out.
FYI, accessing some of the best Prime Day deals does require a membership, however if you haven't used a free trial already you can sign up for a free 30-day run today to take advantage of the deals below. Happy hunting!
Sign Up For Amazon Prime Here
Echo Auto
echo auto
Easily add Alexa to your car with an Echo Auto, which is just $19.99 during Prime Day. The Echo Auto connects to the Alexa app on your phone and plays through your car’s speakers, either through auxiliary input or your phone’s Bluetooth connection. Featuring eight microphones and far-field technology, this device is capable of listening for your voice over your music, A/C, and road noise. Add the ability to voice control Echo Auto to stream from various services including Audible, Amazon Music, Apple Music, Spotify, SiriusXM, and more. You can also use your voice to play music, check the news, make calls, add to your to-do list, set reminders, etc.
Just make sure you check that Echo Auto is compatible with your car prior to purchasing. It’s currently 85% off ($14.99) and includes six months free of Amazon Music Unlimited.
Check out the Echo Auto Here
LED Headlight Bulbs
Best LED Headlights
Photo credit: Jodi Lai / AutoGuide.com
LED headlight bulbs are an affordable way to upgrade your car’s factory lighting. Not only are LED headlight bulbs generally brighter than halogen headlight bulbs, they last a lot longer too. Most aftermarket offerings are fairly straightforward to install and are universal—just make sure you’re getting the correct fitment for your vehicle.
When shopping for LED headlight bulbs, their brightness is measured in lumens, so choose accordingly to how bright you want your bulbs to be. If you often drive at night, you’ll also want to compare advertised operating life among different options. Expect most LED headlight bulbs to last tens of thousands of hours. Another factor to consider is ensuring that they’re approved for use by the U.S. Department of Transportation (DOT) and your local state laws, since they are brighter than standard headlights.
Prime Day Deals On LED Headlight Bulbs:
SEALIGHT LED Headlight Bulbs Combo Package – $59.49 (26% off plus additional promotional discounts)
Torchbeam LED Headlight Bulbs – $33.99 (26% off)
SEALIGHT S1 Series LED Headlight Bulbs – $33.99 (32% off)
Otium LED Headlight Bulbs – $22.09 (39% off)
Check out Deals on LED Headlight Bulbs
Portable Jump Starters
top 10 best portable car jump starters
Photo credit: Stanley
Recently, portable jump starters have increased in popularity, especially since many of today’s offerings also serve as battery banks for your mobile devices. These compact jump starters are great for emergency use, giving your car’s battery the boost it needs to start without needing another vehicle and using jumper cables. And at their price, we recommend every car owner keeps one handy inside their glove box.
The main factor you want to consider when picking a portable jump starter is your engine’s size. You’ll find that these devices have different peak current ratings, so make sure you’re buying one that is powerful enough for your vehicle. If you’re choosing an option that can also be used as a battery bank, check its battery capacity (measured in mAh). This will explain how many times you can recharge your devices before the portable jump starter itself needs to be recharged.
More premium options will include a cigarette lighter adapter to power 12V devices, and built-in LED flashlights. And if you have a phone with USB-C charging, you’ll likely want to pick a portable jump starter with USB-C ports.
Prime Day Deals on Portable Jump Starters:
HULKMAN Alpha85 Jump Starter – $99.95 (23% off, plus save an additional 10% with coupon)
AVAPOW Jump Starter – $50.99 (34% off)
FOXPEED Portable Jump Starter – $59.99 (25% off, plus save an additional 15% with coupon)
Check out Deals on Portable Jump Starters
Battery Maintainers
Photo credit: oatpenz studio / Shutterstock.com
While portable jump starters are great for firing up your car when the battery’s dead, it’s even better to ensure your car’s battery is in good condition and always has a charge. Battery chargers, as their name suggests, are designed to simply charge your car’s battery. Battery maintainers, also known as float chargers, not only charge your battery but ensures it won’t be damaged in the long term by maintaining a charge.
So how do you choose whether you want a basic battery charger or a more complex battery maintainer? Battery maintainers are ideal if your vehicle is going to sit parked for an extended period of time. Hook it up to your car’s battery and it’ll do all the work—charge it to capacity, and then switch to float mode, where it’ll only resume charging when the battery naturally drops below a certain threshold. Battery chargers, or trickle chargers, will just charge your car’s battery and shouldn’t be used long term.
Check out Deals on Battery Mainteners
Portable Tire Inflators/Air Compressors
best portable tire inflators air compressors
Photo credit: NATALLIA B / Shutterstock.com
Having properly inflated tires is an often overlooked factor when it comes to car maintenance. Driving on underinflated or overinflated tires will affect your vehicle’s ride quality, as well as its fuel economy. Just because your car is equipped with a tire pressure monitoring system (TPMS) doesn’t mean you can ignore your car’s tire pressure.
Owning a portable tire inflator or air compressor means you can check your tire pressure from the comforts of your own home and inflate your tires if necessary. These products generally use your car’s cigarette lighter receptacle for power, although others can use a standard household power outlet. Some offerings will have some additional features, such as a built-in LED flashlight and auto shutoff feature. We recommend getting a portable tire inflator that allows you to preset your desired tire pressure, and it’ll automatically shutoff once it reaches that value.
Here are some factors you’ll want to consider when choosing a portable tire inflator. Check to see how quickly a product can inflate your tires. While this may not matter to most users, you also don’t want to spend 10 minutes putting air into your tires. If you own a larger pickup truck, you’ll want to ensure the tire inflator is capable of inflating your tires. Pay close attention to the length of the power cable and the hose to ensure you’re able to reach the front and rear tires without having to constantly unplug the unit. Lastly, a warranty is always recommended with a portable tire inflator.
Prime Day Deals On Tire Inflators:
GSPSCN Silver Tire Inflator – $50.88 (33% off)
H Helteko Portable Air Compressor/Tire Inflator – $25.49 (43% off)
Check out Deals on Tire Inflators
Car Detailing Supplies
best car detailing products
Photo credit: hedgehog94 / Shutterstock.com
What better time than now to stock up on car detailing supplies? From car wash soaps to spray waxes, tire shines to microfiber towels, you’re sure to find some real good deals during Prime Day. So what are some things to look out for while shopping this year?
Start with the basics and get yourself a quality car shampoo, wash bucket, and mitt. You’ll want a good drying towel too. If you really want to make your life easier and give your car a thorough cleaning, keep an eye out for a good deal on a pressure washer. But that just mainly covers washing your car—if you want it to shine for a long time, you’ll want to also pick up a clay bar and wax. Ceramic detailing products are a great way to go as well! Put the finishing touches on your exterior with proper tire shine.
But you don’t want to forget your interior either. Compact car vacuums are a great way to get your cabin nice and spotless with little effort. Grab yourself a bottle of upholstery cleaner to wipe down your dash, seats, center console, and more. And if your floor mats and carpet is a bit rough and needs some care, add some carpet cleaner to your cart before you check out.
Prime Day Deals on Car Detailing Supplies:
Carfidant Black Car Scratch Remover – $16.95 (43% off)
Meguiar’s Hybrid Ceramic Wax – $16.83 (23% off)
Chemical Guys HydroSlick & HydroSpeed Bundle – $53.35 (18% off)
Check out Deals on Car Detailing Supplies
Mechanic's Tools
mechanics tools
Photo credit: Studio 72 / Shutterstock.com
Are you a home mechanic and love working on your car? Now’s the time to get yourself that comprehensive socket set or cordless drill you’ve been waiting on. But along with ratchets and wrenches, don’t forget other accessories like a tool box or tool bag to help keep everything organized. If you regularly perform general maintenance on your car, don’t overlook specialty tools such as a spark plug socket, oil filter wrench, or even an OBD2 scanner that can help diagnose check engine lights. It’s a pretty good idea to get a garage work light or two.
We also recommend grabbing a pair of durable gloves for working on your car, or even a box of disposable gloves. Lastly, don’t forget a creeper seat, which your body will thank us for later.
Prime Day Deals on Mechanic’s Tools:
LEXIVON 1/2-inch Drive Click Torque Wrench – $29.72 (46% off)
AUTOPHIX OBD2 Scanner – $35.77 (28% off)
Medoga Car Trim Removal Tools – $16.79 (30% off, plus an additional 5% with coupon)
Autel OBD2 Scanner – $19.54 (33% off)
Check Out Deals on Mechanic’s Tools
Windshield Wipers and Windshield Washer Fluid
top 10 best windshield wipers
Photo credit: Sashkin via Shutterstock.com
For some areas in the U.S., you’re probably getting ready for a season of rainy weather. That means it’s the ideal time to swap out your windshield wipers for new ones. Extremely important when it comes to safety, poor wipers affect visibility while driving in the rain and you don’t want to wait until you’re caught in a storm before realizing you need replacements wiper blades.
If you think just finding a set of windshield wipers that fit your car is all you need to do, think again. There are different types of wiper blades on the market and some perform better than others in certain conditions. The most common type are traditional frame-style blades, featuring rubber squeegees or halogen-hardened rubber. You might also see them referred to as bracket-type wipers. Typically these blades are the least expensive, but vulnerable to snow and ice.
Hybrid blades have a similar construction to frame-style blades, but they have an added outer shell to keep snow and ice off the blades themselves. The shell also provides a lower-profile, more aerodynamic design. The last type you’ll likely find while shopping are beam-style wipers, which are generally the most expensive. They are also the most durable, lasting longer than conventional wipers.
If you live in an area that experiences a lot of rainfall, you’ll want to go for beam-style wipers. See rain every couple months for a day or two? Save yourself some cash and get frame-style blades. If you’re dealing with ice or now however, you’ll likely prefer hybrid blades.
Don’t forget to stock up on windshield washer fluid too!
Prime Day Deals on Windshield Wipers and Windshield Washer Fluid:
ABLEWIPE Wiper Blades – up to 33% off depending on size
Check out Deals on Windshield Wipers & Washer Fluid
Car Covers
best car covers
Photo Credit: Robert MacMillan / Shutterstock.com
If you plan on parking your car for an extended period of time, you’ll want to invest into a quality car cover. Even if you’re storing your car inside a garage, you’ll still want a car cover to keep dust and accidental scratches off your car’s surface. Car covers also come in handy to protect your car overnight, if you’re having to park outside.
There are so many options when it comes to car covers, that we wouldn’t blame you if you’re overwhelmed when shopping. Picking the right one largely depends on the environment. You’ll want a heavy duty, multi-layered cover if your car is going to endure rainy and snowy weather. If windy conditions are your concern, make sure you get a cover with additional straps and buckles so it doesn’t blow off as soon as you walk away from your car.
If you’re parking indoors, you may not think you need much and that a basic car cover will suffice. But in that scenario, look for an actual indoor car cover, as the materials and the cover itself will be designed for indoor use.
Check out Deals on Car Covers
Dent Repair Kits
Best Dent Repair Kit for Cars
Photo credit: CC7 / Shutterstock.com
Getting a dent in your car can really ruin your day. The unsightly appearance of even the smallest door ding can be extremely noticeable to you, but sometimes it’s not worth the hassle to take it to a body shop or call up a local paintless dent removal company. That’s where DIY dent repair kits come in handy, but only if you have the patience to learn how to use them.
These do-it-yourself kits typically come with a plethora of different tools to accommodate dents of all sizes. Some work better than others, but all of them require the time to learn how to use them properly. If you’re willing and able, you might end up saving hundreds of dollars repairing that dent yourself.
Most kits will require using a hot glue gun and applying a tab to the dent. You then use the dent lifter, puller, or bridge board to pull out the dent. There are also metal tap down pens you can use, although those require a bit of expertise.
So if you have the patience to try to pull a dent yourself, grab yourself one of these kits. Get ready to pop some popcorn and watch some YouTube videos though, so you know what you’re doing and not further damaging your car.
Check out Deals on Car Repair Kits
Seat Covers
best car seat covers
Photo credit: welcomia / Shutterstock.com
When it comes to your interior, your car seats experience the most wear and tear on a daily basis. If you value your investment, you’ll want to protect those seats. Or maybe you’re just not a fan of how drab the factory seats look and want to add more color to your interior. Either way, car seat covers are a cost-effective way to protect your seats and since they’re available in a variety of styles and sizes, you’ll likely find something that matches your personal style.
One thing to keep in mind when it comes to car seat covers is that most of them are designed to be a universal fit. That means most owners won’t have any issue installing them onto their seats, but some cars it may be more difficult. You’ll also want to ensure whichever seat cover you’re purchasing won’t interfere with side airbag deployment, if your vehicle is equipped with side airbags.
With all the different materials you can choose from, you’ll need to decide what you want. Seat covers with neoprene material offer great water resistance, protecting your seats from mud and rain. If you want a more high-end, luxurious appearance, there are plenty of artificial leather seat covers out there that offer great protection and attractive styling. The more affordable seat covers typically use polyester material, which gives you a soft touch cover that’s highly absorbent. These are typically machine washable, which requires a bit more maintenance than simply wiping down an artificial leather cover.
Prime Day Deals on Seat Covers:
Lassie Back Seat Dog Cover – $19.50 (46% off)
Check out Deals on Seat Covers
If you’ve made it this far you’ve likely realized that there’s a lot going on for Prime Day this year, and hopefully you’ve found a few useful deals and saved a few bucks along the way. Was there anything specific you were looking for that you didn’t find here? Let us know in the comments below. We’ll also welcome any additional deals that you may have spotted that our team may have missed out on. Either way, good luck with the bargain hunting!
1 - 2 of 2 Posts
