I thought that the 06 Toyota Sienna is pretty good. However, it belongs to worst year based on this article: 8 Best And Worst Years For The Toyota Sienna Ranked In 2022 Any thoughts?
Based on the fact that you own a 2006, what are your thoughts on it?
And since this model was from 2004 to 2010, how is it that 2009 was one of the best years? Doesnt make any sense to me.
We owned a 2006 from brand new for 10 years and had 1 warranty claim and zero other issues.
I now own a 2020 and dont like it nearly as much as our 2006. Less features, way more squeaks and rattles, brutally stupid drivers side arm rest position etc.
I too had a slow freon leak for years and I found it when I pulled the front bumper off to install a transmission cooler. Facing the van it was the upper left hand corner and the black oil residue on the fins was the dead give away. You can remove the upper black plastic cover in that area and use a flashlight and a mirror to examine. You could also peek between the slim grill areas located just above and below the Toyota emblem. I got lucky as I feared my leak would have been in the evaporator area. That would be tough were it so.BTW, there is slow Freon leak, I add freon if needed for the last few years.
Did you mean 216000 miles?My 06 has been bullet proof. My Mother in law bought brand new and gave it to my sister in law who ran it into the ground. SIL bought a new car and was sending the Sienna to the scrap yard but I asked for it. Was gifted the van for free. I took hold of it at 116k. Changed lower control arms/bushings, stabilizer links, front rotors/hubs/bearings, rack and pinion, timing belt/radiator/thermostat/hoses, motor mounts. All parts have been from Rock Auto. I've spent about 2k in total and the van is my daily driver. I drive 80 miles daily to work and home. Best vehicle i have ever owned. I have the CE and it's great for trips, beach, park and for transporting the grandkids. It is rust free. Only thing that I need to do next is replace the oil and trans pan gaskets. I believe in preventive maintenance so I replace wear items before failure. Sienna still has original starter, alternator and fuel pump which I will be switching out soon. Sister in law hit a pole with the plastic bumper. Been meaning to use a heat gun to take the dent out. I currently have 254k miles. Run Valvoline synthetic oil on the Sienna.
