Howdy All -
I bought a new set of non-HID headlights off of eBay in January, and was being a lazy-but and didn't get around to installing them until last week. Much to my horror, I found out that I should have purchased HID headlights instead. And then when I priced out replacement HID headlights, I was REALLY horrified.
So my question is this... can I take my nice new non-HID assemblies and Frankenstein in my HID guts to come up with a functional and reliable HID assembly? Yes, I have a dremel, and I'm not afraid to use it...
Or should I just put these new lights in the classifieds and try a lens restoration kit instead?
Thanks!
I'm no expert but I'd compare the bulbs and observe the light source location. If not identical the reflector housing would scatter light all over hell.
That's a good point...
I wonder if I can simply "downgrade" to the new lights as they are? The HID lights have 5 wire inputs, whereas the non-HIDs only have 4.
Want to sell them?
I've got a Gen 2 non-HID 2006 LE and I've been thinking it needs a little refreshing.
I made the same mistake. 2008 Limited with HID lights that were terribly faded. The new non-HID headlight assemblies came with new bulbs included and I was able to modify the existing wiring for the HID to work with the new bulbs. It's a bulb and only needs hot and negative after all. There were some extra connectors that were not needed for the new standard bulbs. It appears the original HID lights had a 'tilt' feature that would raise or lower beam based on speed? At any rate the new headlights work well and light way better that the old faded HID assemblies.
