Can't reach 2020 Toyota Sienna LE to pull down rear hatch!
1380 Views 4 Replies 3 Participants Last post by  Gary Stamey
Sitting in wheelchair, can't reach to pull down 2020 Sienna LE rear hatch.
Is there an "add on" to make rear hatch door automatic open/close or ?
Guess I could DRILL A HOLE and attach a pull down strap,etc?
An LE van might not be the best choice for you given your situation. XLE comes with a motorized hatch, IIRC.
Straps can be problematic if they don't retract, as if it's mounted on the inside it will invariably end up pinched in the seal on closure. I have heard of aftermarket kits, but the Sienna system is a bit unique (different from the RAV4 and Highlander in architecture), so likely not as common. Perhaps the inner panel, motor and drive from a wrecking yard Sienna could be grafted in.
Hmmmm, will get reached stick with a book to go reach slightly inside recessed pull down handle...tried it several times, it tends to slip, but does work...liked xl e model, but all were nearly $4000+ !
I'm getting a red flag for shared IP addresses. Why did you register again under a new name?
I was looking at this forum from a new Android tablet and mistakenly signed up there also..Guess'n I can delete that membership?
Mostly I come on-line with a PC..:-(
