DNX994s - $400
The Kenwood Excelon DNX994S navigation receiver does way more than just meet the strict criteria for Kenwood's prestigious "Excelon" badge — high-voltage preamp outputs, audiophile-quality audio components, and a 2-year warranty. It also delivers user-friendly control with a 7" multi-touch display, amazing smartphone integration, and accurate GPS guidance from the experts at Garmin. With the DNX994S in your dash, you'll have a wealth of options for info and entertainment right at your fingertips.
iDatalink Maestro RR - $100
iDatalink's Maestro ADS-MRR module, along with the correct interface harness for your vehicle, allows you to install a new car stereo in select 2006-up Ford/Lincoln/Mercury, GM, Chrysler/Dodge/Jeep/RAM, Toyota/Scion, Honda/Acura, Fiat, Subaru, and Volkswagen/Audi vehicles while retaining your factory steering wheel audio controls and the use of your factory amplifier, if present.
Pioneer TS-SWX251 - $75
Pioneer's TS-SWX251 loaded enclosure offers a space-saving solution for vehicles with limited room for a sub. This rugged enclosure comes preloaded with a shallow-mount TS-SW251 10" sub — at under 6" deep, you can fit it just about anywhere.
JL Audio JX360/4 – $150
You know you're holding a serious piece of sound equipment when you feel the heft of a JX amp. JL Audio designed these amplifiers with sturdy, high-grade parts that ensure excellent heat management, provide high current flow, and deliver stable performance in almost any situation. You won't find blinking lights or meters on the outside of these amps, but you will find oversized output transistors and rugged MOSFET power supplies inside. The sleek, high-mass aluminum heatsink keeps things cool enough to virtually eliminate thermal shut-downs.
9005 Morimoto HID kit w bulbs - $100
Toyota OEM Roof cross bars - $75
All items in excellent condition, local pickup preferred. May ship at buyer's expense.
