1 - 20 of 23 Posts
Many have expressed interest (frustrations) in changing certain customizations settings on their Siennas without involvement with the dealer. Checkout www.caristaapp.com for more details. Currently the Gen 4 2021 Sienna is not a listed supported vehicle, so I plugged in my Carista OBD2 tool and read what is currently supported on Gen 4 below. When Gen 4 is explicitly supported there will be more customizations available.
The following settings are from my Platinum AWD, your model may have a few less (e.g. rain sensing wipers/HUD display) using Carista:
Chassis & Engine
Active Noise Cancellation (ANC)
ON / OFF
Engine Sound Enhancement (ESE)
ON / OFF
Dings & Warnings
Seat belt warning ding (driver)
ENABLED / DISABLED
Seat belt warning ding (front passenger)
ENABLED / DISABLED
Seat belt warninig ding (rear right passenger)
ENABLED / DISABLED
Seat belt warninig ding (rear left passenger)
ENABLED / DISABLED
Seat belt warninig ding (rear center passenger)
ENABLED / DISABLED
Driver Assist
Default distance for Pre-Collision System (PCS) alarm when the PCS switch is turned off and back on
NORMAL / REMEMBER LAST DISTANCE
Default distance for Pre-Collision System (PCS) alarm when the ignition is turned on with the PCS switch off
Default distance for Pre-Collision System (PCS) alarm when the ignition is turned on with the PCS switch on
Instruments: Displays & Nav
Display odometer after ignition is turned off for…
30 SECONDS / 1 MINUTE / 10 MINUTES / OFF
Instruments: Heads-Up Display (HUD)
Image distortion in heads-up display (HUD)
CONCAVE HIGH / CONCAVE MEDIUM / CONCAVE LOW / DEFAULT / CONVEX LOW / CONVEX MEDIUM / CONVEX HIGH
Lights: Exterior
Lane-change turn signal auto-flasher count
OFF / 3 FLASHES / 4 FLASHES / 5 FLASHES / 6 FLASHES / 7 FLASHES
Turn signal click volume
LOW / MEDIUM / HIGH
Parking Sensors
Parking sensor beep volume
LOW / MEDIUM / HIGH
Rear center parking sensor range
SHORT / LONG
Seats & Steering Wheel
Easy entry/exit
DISABLED / RETRACT STEERING WHEEL FOR EASY ENTRY/EXIT / TILT AWAY STEERING WHEEL FOR EASY ENTRY/EXIT / RETRACT AND TILT AWAY STEERING WHEEL FOR EASY ENTRY/EXIT
Trunk
Rear hatch open assistance
ENABLED / DISABLED
Rear hatch max open level
1 / 2 / 3 / 4 / 5 / USER-SPECIFIED
Unlock via "One motion"
REAR HATCH ONLY / ALL DOORS
Open rear hatch via "One motion" remote
DISABLED / SINGLE CLICK / DOUBLE CLICK / LONG PRESS / DOUBLE CLICK ON UNLOCK BUTTON / LONG PRESS ON UNLOCK BUTTON
Open/close power rear hatch via interior switch
ENABLED / DISABLED
Open/close power rear hatch via interior switch (click type)
SINGLE CLICK / LONG PRESS
Beep while opening/closing power rear hatch
YES / NO
Beep volume while opening/closing power rear hatch
LOW / MEDIUM / HIGH
Windows & Sunroof
Open driver's window using single button press
YES / NO
Close driver's window using single button press
YES / NO
Open passenger's window using single button press
YES / NO
Close passenger's window using single button press
YES / NO
Rear-left window single-touch-close
YES / NO
YES / NO
Rear-right window single-touch-close
YES / NO
YES / NO
Passenger window single-touch-open from driver's switch
YES / NO
Passenger window single-touch-close from driver's switch
YES / NO
Rear-left window single-touch-open from driver's switch
YES / NO
Rear-left window single-touch-close from driver's switch
YES / NO
Rear-right window single-touch-open from driver's switch
YES / NO
Rear-right window single-touch-close from driver's switch
YES / NO
Wipers & Washer
Automatic wipers (using rain sensor)
YES / NO
Obtained with Carista 5.5.1 for iOS.
2021 Sienna XLE Plus
@mnmpizza this solves your ghost seat belt issue if nothing else works. I forget what Carista costs but i think if you buy the adapter for like 30 or 40 bux you get a 1 month trial of the app that you would use to customize/change features.
You don't have to buy their adapter. It works with a generic ELM327 Bluetooth adapter. You can do a trial and see what customizations are available before you buy. Unfortunately the number of available customizations for Toyota seems quite limited compared to some other makes like VW. What I really would have liked to see is a way to disable the cold weather chime and fast flashing when using aftermarket LED rear turn signals, but that doesn't look like it's going to be possible.
Please try turning engine sound enhancement (ese) off and let us know if the engine noise on acceleration is reduced.
Someone posted on FB, that ESE uses the vehicle speakers to make the engine seem louder. Crazy. Why would Toyota do that?
Maybe in sports mode to psych you into thinking you are driving a $100k plus sports car? Some like the purrrrr...lol. Me, I am in a hybrid and want it to sound like a quiet hybrid.
2022 XSE+TP AWD
Standard ELM327 plus Torque will do all that? I will try that on 3rd gen Sienna this weekend, don't have 4th gen in hands just yet.
I read the same FB thread. From what they said, turning on the active noise cancellation(ANC) and turning off the Engine sound enhancement (ESE) made a big difference. I have a 21 xse w/jbl audio and I used a Carista adapter, I do not have an option for either of these changes. It must only be on higher models?
According to @Dimitrij at his most recent service, the Toyota tech indicated it is only on highest trims (Platinum, maybe Limited).
If the dealership is correct, we may be witnessing an interesting phenomenon: When the premium we pay for a higher trim saddles us with blatantly useless features that are hard to get rid off.
This is by no means a new phenomenon. It was mentioned in the immortal musical Fiddler on the Roof, where Tevye the Milkman is describing a top of the range house with no fewer than three staircases: one going up, the other (the longer one) going down, and the third one going nowhere, "just for show".
This is by no means a new phenomenon. It was described in the immortal musical Fiddler on the Roof, where Tevye the Milkman is describing a platinum trim house with no fewer than three staircases: one going up, the other (the longer one) going down, and the third one going nowhere, "just for show".
Well, we only think it is “useless” based off of one person on Facebook saying so. Unless I missed others confirming this makes any kind of difference.
I have a Platinum and have 0 complaints about the noise level. I frequently ride with the sound system off (after dropping kids at school, need some peace and quiet), and I have a hard time believing that engine noise is being pumped into the cabin. If so it is the most imperceptible engine noise enhancement system on the planet. The Sienna is quieter than either of our previous two Priuses and light years quieter than either my 06 or 17 Tundra. I owned a BMW with active sound enhancement - very noticeable. That car was also much louder overall than the Sienna.
I would be tempted to buy Carista if I thought it was an issue — or even noticeable.
By the way, love the Fiddler on the Roof reference. First stage production I ever saw live.
As BearInStPete did above for a Platinum, here are the options available for a Limited AWD:
Dings & Warnings
ENABLED / DISABLED
ENABLED / DISABLED
Seat belt warning ding (rear right passenger)
ENABLED / DISABLED
Seat belt warning ding (rear left passenger)
ENABLED / DISABLED
Seat belt warning ding (rear center passenger)
ENABLED / DISABLED
Driver Assist
Microphone sensitivity
3
Lights: Exterior
LOW / MEDIUM / HIGH
Lights: Interior
Turn on interior lights when you shut off engine
YES / NO
Parking Sensors
LOW / MEDIUM / HIGH
Front corner parking sensor range
SHORT / LONG
SHORT / LONG
Easy entry/exit
Trunk
ENABLED / DISABLED
ENABLED / DISABLED
YES / NO
LOW / MEDIUM / HIGH
Windows & Sunroof
Open windows and sunroof via long-press on remote
ON / OFF
Open windows and sunroof by turning and holding key in door lock
ON / OFF
Close windows and sunroof by turning and holding key in door lock
ON / OFF
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
Obtained with Carista 6.3.3 for iOS.
I tried to change the following to SINGLE CLICK from LONG PRESS ON UNLOCK BUTTON (default) thinking it would allow the rear hatch to open as such, but this made it so the sliding doors and the rear hatch inoperable with the remote.
Hello. Here is what i see for a 2021 XLE AWD (Canada) as of the posting date.
I'm using the beta version of the app and it looks like they just released some new customizations in there. There is one that I had been waiting for which is a calibration feature for the ambient temperature level. It's possible to adjust this now +/- 1, 2 and 3 degrees. My temperature readings have been 2-3 degrees off so this is very welcome. There may be some other new features in beta but none that I would care about. Still waiting for the ability to turn off the "roads may be icy" alert!
1 - 20 of 23 Posts
