From feeling around, it seems like there is a fairly sizable space between the bottom of the door cage and the bottom of the cubby. In the next few weeks, I will be attempting to disassemble mine to see what, if anything can be done.Does anybody know if the inner liner at the bottom of the cubby sits flush on the floor or whether there is a gap under there whether a drill hole saw could make a clean cut on the bottom.
Do you have an update? My console just ate something and now it is stuck.From feeling around, it seems like there is a fairly sizable space between the bottom of the door cage and the bottom of the cubby. In the next few weeks, I will be attempting to disassemble mine to see what, if anything can be done.
The bottom is a false bottom. I didn't take a great picture of it but I attached a photo to give you an idea. If you wanted to dremel and not remove the entire box then you can do so, but will need to cut about an inch or so above the bottom. In my opinion the hardest part would be cutting the vertical lines. I had to use a mini hand saw due to the angle you cannot get a dremel in. Unless you had a dremel attachment or use some type of angle cutter like a multi-tool. You might end up cutting into the bottom of the lid, however you would never see those cuts. Honestly it is easier just to remove the whole box out and cut it when it is outside.Does anybody know if the inner liner at the bottom of the cubby sits flush on the floor or whether there is a gap under there whether a drill hole saw could make a clean cut on the bottom.
Also I wonder if a close quarter 90 degree angle drill and a round hole saw with a fine tooth used for door locks would make a decent opening that could be left open or patched later made in the inner side. I suspect a round hole might be as good as a not so square opening. Harbor freight has cheap compact close quarter 90 drills.
Harbor Freight or Home DepotYou are so awesome man! now to find myself a mini ratchet.
I already have a dremel tool. Might get the mini ratchet through amazon though. This will definitely be one of my projects in the next few weeks. Admin, if you are reading this, you might consider this solution to be stickied! You are a super star @Velox003Harbor Freight or Home Depot
Yea I didn't want to create a new thread for this because this was ongoing. I wish I could have done a "how to" but I had to watch my 2 little kids who were in the back seats watching a movie.I already have a dremel tool. Might get the mini ratchet through amazon though. This will definitely be one of my projects in the next few weeks. Admin, if you are reading this, you might consider this solution to be stickied! You are a super star @Velox003
Good question, I mainly cut it this way to maintain rigidity to the box. However I think you could cut it all the way down. The plastic is quite stiff so I don't see any harm cutting it further. I just got lazy and wanted to reinstall it.Reposting this as you might have missed my edit.
By the way, if you would have to do it again, would you rather have the cut portion shorter to be aligned where the slope ends? or would you rather keep the same as you did?
Got it. I might do it the same as how you did it.Good question, I mainly cut it this way to maintain rigidity to the box. However I think you could cut it all the way down. The plastic is quite stiff so I don't see any harm cutting it further. I just got lazy and wanted to reinstall it.
Also I kept the sides wider thinking I will install a new plastic wall and velcro it somehow.
Sorry I don't understand your question, while it was attached to?@Velox003 Did you cut it while it was attached? or did you have to take it out?
No it was way easier to cut it when it was removed. My lid was stuck halfway so it was impossible to get anything in there to cut it. Removing the box sounds and looks difficult, but it really is not that hard. Finding the right screws to remove and getting access to them was the hardest part. Shouldn't take you more than 30min.Sorry I meant, did you cut the plastic while it was mounted on the car?
Thanks. Sorry but I still have one last question (hopefully), and might be a silly question but are you able to take it apart without touching the driver side? or do you have to undo the screws and clips on the driver side as well?No it was way easier to cut it when it was removed. My lid was stuck halfway so it was impossible to get anything in there to cut it. Removing the box sounds and looks difficult, but it really is not that hard. Finding the right screws to remove and getting access to them was the hardest part. Shouldn't take you more than 30min.
Unfortunately in order to fully remove it both sides have to come out because there are screws in the side holding the box down. It really is not too hard to do. Just finding the screws and reaching in with the micro ratchet is the hard part.Thanks. Sorry but I still have one last question (hopefully), and might be a silly question but are you able to take it apart without touching the driver side? or do you have to undo the screws and clips on the driver side as well?
