My 2008 Sienna has a clunk that can be felt as much as heard when turning with steering wheel full lock to the left. My wife noticed it when backing out of a parking spot.
It doesn't sound like the worn CV clicking I'm used to hearing, but kind of acts like a bad CV joint, so I won't discount that possibility.
I've read other suggestions that it could be a lower control arm, but the thing is that the clunk will repeat continuously if I drive in a full circle several times without changing steering at constant (slow) speed. I'd expect one clunk if it were a LCA for every hard turn, not multiple ones.
It feels like a small lunge or shift with each clunk, like a knee giving out or something similar.
Any suggestions before digging into it? It drives fine otherwise.
First check is to jack up the wheel and make sure the wheel is on fully with the lug nuts fully seated/torqued. Then, give the wheel a side-to-side and a top-to-bottom vigorous shake to check for bearing play and steering play. If nothing obvious pops out, it's probably the half shaft.
I did that yesterday and there was no play when shaking from top-bottom, but there was play when shaking side-side. I crawled under it with my son shaking it, and it could be heard , but I could not locate it. The sound/play was not coming from the wheel area as far as I could tell. Driving it again, there was so much a sound as a feeling of giving/play at certain points of rotation of the wheel, but not completely repetitious.
What part of the half-shaft goes bad? The inner tripod bearing/joint is the only thing I can think of.
I took it to a mechanic friend of mine and he drove it without noticing any problem. We did tight circles in his drive, and whenever I pointed out what I felt, he said that was just a crack in his drive. I went back to the school parking lot and did the same, convincing myself that I was feeling it. But then I noticed that every time I had the slip/lunge feeling, it was when I was crossing a painted line. Looks like he was right - no actual problem with the van. My wife swore she heard something initially a few days ago, which was what started this whole thing, so we'll keep an ear out for it, but that's about it for now.
The thing is, if you had side-to-side play and it wasn't the wheel bearing, it's likely the steering joints. That can be totally not seen/felt on a smooth, flat area. It often only seems to manifest in heavy traffic in a work zone with jersey barriers on one side and certain death on the other.
