1 - 2 of 2 Posts
Saludos .tengo sienna 2004 con 60,100 millas y los abanicos del motor y el aire acondicionado y la memoria, los relés y los fusibles se activan y se activan, se debe cambiar el sistema de la computadora.
Translated by Google: "Greetings .I have 2004 sienna with 60,100 miles and the engine fans and the air conditioning and memory, relays and fuses go on and off, computer system needs to be changed."
How did you make out with your problem?
Reactions: fibber2
1 - 2 of 2 Posts
