1 - 8 of 8 Posts
My 98 seems to take longer starting when it's cold than after I ran it for a few miles. I know this is somewhat normal but did anyone eventually have a problem with this?
I read that leaky injectors cause hard starting when the engine is hot. I was just wondering if anyone else has this problem. It cranks like 4 times before starting when it's cold
Low fuel pressure? Turn ignition on. Listen for fuel pump to stop. Turn off. Turn on. Listen to fuel pump run then stop. Now start van. This will prime up the fuel rail to correct pressure. It the system is not holding pressure over night.
I read In toyotnation that they don’t return fuel to the tank. Thus no regulater. You might double check me on this
1 - 8 of 8 Posts
